Fast ethernet monitoring issue
gopinathan.k
We have two routers connected to MPLS cloud over Wireless (the IDU is connected to router to FAstethernet). We are finding it difficult to findout whether the wireless is up or down, since your Connectivity to IDU will be always UP (eventhough the wireless is failed). IS there any way to monitor WAN Wireless connectiviy through fastethernet. Please find the attached diagram form more clarity
amit-singh
Level 8
Level 8
I think you can look for route object tracking and it should help you in this case. Please have a look at it:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5413/products_feature_guide09186a00801d862d.html
HTH, Please rate if it does.
-amit singh
