Bookmark
Subscribe
4379
which switch models support dual power supply
konda2004
which switch models support dual power supply.That means another should be redundant and should be up when one fails.we want them for data centres
amit-singh
Level 8
Level 8
Catalyst 4900's, Cat4500 and Catlyst 6500's.
HTH,
-amit singh
Hi Friend
As Amit has already said, all modular switches like the 4500 & the 6500 have dual power supplies.
THe 4948 is a new fixed configuration switch with redundant power supplies.
you can also consider using cisco RPS 675 high availabilty redundant power supply which is compatible with most of the switches like 2960, 2560 & 3750
HTH, rate if it does
Narayan
