Fast PoE and Perpetual PoE on Catalyst 9400
jacardi13
Does anyone know if fast PoE and Perpetual PoE are available on Catalyst 9400 switches ?
If yes, do you have any release to recommand me ? Right now I'm using version 16.9.4 (Fuji) but these features do not seem available..
Thanks in advance.
Jon
5 Replies 5
Hi and thank you for your answer.
I tried Gibraltar (version 16.12.1) but I only see the following commands :
Switch(config-if)#power inline port ?
1-event Enable 1-event classification, applicable only when port is in upoe-plus mode
2-event Enable 2-event classification
priority set power priority of the port
 For information I'm testing with 2 differents line card models (C9400-LC-48U, C9400-LC-48UX)
Leo Laohoo
16.9.4 support Perpetual PoE and Fast PoE.
The commands are:
power inline port poe-ha
power inline port perpetual-poe-ha
To get it to work, you need to do the following:
1.  Configure the two commands into the interface;
2.  Connect the PD units to the port and wait for them to completely boot up; and
3.  Reboot the switch or line card.
On 9400 I only have this command :
 On 9300 it works well :
2x-mode Apply 2X power level to the port
no-xtalk-wa Disable MagJack XTalk workaround
perpetual-poe-ha Apply perpetual poe-ha to the port
poe-ha Apply fast poe-ha to the port
You're a Cisco Partner. Talk to the BU.
I suspect this feature is not yet enabled on the 9400 line cards.
