Fetch TV & Cisco 877 IGMP/Streaming
jeffreysims83
Hi Guys,
Hoping someone could help me, I'm trying to configure my Cisco 877 ADSL border. It uses the ATM interface to talk to the ADSL. The fetch TV uses Multicast IP streams for the "on demand" TV
Here is my config:
version 15.1
no service pad
service timestamps debug datetime
service timestamps log datetime
service password-encryption
hostname modem
boot-start-marker
boot system flash c870-advipservicesk9-mz.151-1.T.bin
boot-end-marker
logging buffered 65535
logging console informational
enable secret 5 $1$..Bq$NExIrcIg236vxFoCKMjOC1
aaa new-model
aaa authorization exec default local
aaa session-id common
clock timezone EST 10
clock summer-time AEST recurring last Sun Oct 2:00 last Sun Mar 2:00
clock save interval 8
dot11 syslog
ip source-route
ip cef
no ip bootp server
ip domain name tehintartubes.net
ip name-server 203.0.178.191
no ipv6 cef
archive
log config
  hidekeys
ip ssh time-out 90
ip ssh authentication-retries 2
ip ssh version 1
bridge irb
interface ATM0
description --- Internode ADSL ---
no ip address
no atm ilmi-keepalive
pvc 8/35
  tx-ring-limit 3
  encapsulation aal5snap
  protocol ppp dialer
  dialer pool-member 1
interface ATM0.1 point-to-point
description IPTV-PVC
ip pim sparse-dense-mode
ip igmp unidirectional-link
atm route-bridged ip
interface ATM0.2 point-to-point
ip igmp proxy-service
bridge-group 1
bridge-group 1 spanning-disabled
pvc iptv-vc 0/35
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description --- Ethernet LAN ---$FW_INSIDE$
no ip address
ip virtual-reassembly
bridge-group 1
interface Vlan2
no ip address
shutdown
interface Dialer0
description --- Internode ADSL ---$FW_OUTSIDE$
ip address negotiated
ip nat outside
ip virtual-reassembly max-reassemblies 1024
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap refuse
ppp pap sent-username << TOP SEKRETS >>
no cdp enable
interface BVI1
ip address << TOP SEKRETS >> 255.255.255.252 secondary
ip address << TOP SEKRETS >>3 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
ip igmp helper-address udl ATM0.2
ip igmp mroute-proxy ATM0.2
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip dns server
ip static nat entries for my ports are here
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
logging trap debugging
logging 192.168.12.250
access-list 1 permit 192.168.12.0 0.0.0.255
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
password << TOP SEKRETS >>
no modem enable
line aux 0
line vty 0 4
access-class 1 in
privilege level 15
transport input telnet ssh
scheduler max-task-time 5000
ntp source Dialer0
ntp master
ntp server 211.31.132.130
ntp server 192.231.203.132
ntp server 211.31.132.139
sntp server 192.231.203.132
end
Any help would be appriciated as I can't get the IP Multicast to work across the ATM interface?
Jeff
jeffreysims83
Bump
Thiyagu VG
I'm not seeing "ip multicast-routing" Global Config Command in your posted config. Kindly check and update.
ThiyaguVG.
Here is an updated config that I've added together.
version 15.1
no service pad
hostname modem
boot-start-marker
boot-end-marker
enable secret 5 <>
aaa new-model
dot11 syslog
ip source-route
ip cef
no ip bootp server
ip multicast auto-enable
no ipv6 cef
archive
log config
  hidekeys
ip ssh time-out 90
ip ssh version 1
bridge irb
interface ATM0
description --- ADSL IF ---
no ip address
ip pim nbma-mode
ip pim version 1
ip pim bsr-border
ip igmp version 3
ip igmp limit 64000
pvc 8/35
  tx-ring-limit 3
  protocol ppp dialer
ip multicast boundary 101 in
ip multicast boundary 101 out
ip multicast boundary 101 filter-autorp
bridge-group 1
pvc iptv-vc 0/35
interface Vlan1
description ---AUTHLAN---
no ip address
bridge-group 1
interface Vlan2
no ip address
shutdown
interface Dialer0
description ---PPPDialler---
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap refuse
ppp pap sent-username <> password 7 <>
no cdp enable
interface BVI1
ip address 124.148.137.118 255.255.255.252 secondary
ip address 192.168.12.253 255.255.255.0
ip nat inside
ip igmp helper-address 202.58.240.35
ip igmp version 3
ip http server
ip dns server
ip nat translation tcp-timeout 500
ip nat translation udp-timeout 30
ip nat translation finrst-timeout 30
ip nat translation syn-timeout 30
ip nat translation dns-timeout 30
ip nat translation icmp-timeout 30
<< static translations omitted >>
map-class atm iptv
access-list 101 permit ip 224.0.0.0 31.255.255.255 any
snmp-server community public RW
snmp-server ifindex persist
snmp-server trap link ietf
snmp-server trap-source ATM0
snmp-server location RACK1
snmp-server contact Jeffy
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
control-plane
bridge 1 route ip
line con 0
password 7 <>
no modem enable
line aux 0
line vty 0 4
access-class 1 in
privilege level 15
ntp source Dialer0
ntp master
end
speedy250kmph
Were you able to get this resolved mate?
Thanks!
