04-20-2016 06:05 PM - edited 03-08-2019 05:26 AM
Hi all
I have a
Thanks.
Solved! Go to Solution.
04-21-2016 12:03 PM
04-20-2016 06:20 PM
I use 7.2(0)N1(1) with 2348upq and works fine.
04-21-2016 09:20 AM
Hello Reza,
Thanks for you replay, I have one more question, the connection between the 2348 and the 5600 this should be done via the QSFP or I can use this via the SFP? I dont see any doc about the best practices how to connect them.
thanks!
04-21-2016 12:03 PM
Hi.
The uplink is 40Gig. So it should be QSFP.
