Fiber modular switch
shashi saranga
Community Member
I planning to implement vedio network using cisco , i need to select one switch model that support sfp Ex.3560e-12d .I would like compare some models to select best matches for me. I need more than 12 ports cost effect solutions.If any one can help me regarding this it will be highly appreciated.
shashi
Jerry Ye
Since you've listed the 3560E-12D, assuming you want L3 switches and 10GE ports. You can try the Catalyst 4900M which can supports 24x 10GE ports with L3.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6021/ps9310/Data_Sheet_Cat_4900M.html
If you can wait, the Nexus 5548 L3 module should be available soon where it can supports 48x 10GE ports.
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/data_sheet_c78-618603.html
HTH,
jerry
Leo Laohoo
Jerry has a point but I need more information.  Do you need 1Gb SFP or 10Gb SFP?  Besides, the 3560E-12D does NOT support 10Gb SFP.  The 3560E-12SD supports TWO 1Gb SFP.
How many 1Gb or 10Gb ports do you need?
What is your budget?
