DNS forwarding problem
fearless.rabbit
Level 3
Level 3
Hello everyone,
I have a simple network consisting of 3550 switch, whose only purpose is to separate vlans, and 2800 series router that deals with inter-vlan routing, acl filtering, and dhcp service for all vlans. The idea is to also add DNS forwarding/caching option, so every host inside the vlans can get their default gateway (router subinterface) as their DNS server. Router will not host any zones, just forward and cache queries from ISP DNS.
However, I followed all online instructions on how to configure this, and DNS is still not propagating through vlans. Hosts still have to manually put ISP DNS in order to have Internet. We have a single public IP address, and nat overload is configured. I edited a relevant portions of my configuration, so someone could narrow down the problem. My newbie guess is that ACL might be the issue, but Im not sure which one and why.
interface GigabitEthernet0/0
no ip address
ip broadcast-address 0.0.0.0
duplex auto
speed auto
interface GigabitEthernet0/0.2
encapsulation dot1Q 2
ip address 192.168.2.1 255.255.255.0
ip access-group 1 out
ip nat inside
ip virtual-reassembly
interface GigabitEthernet0/0.3
encapsulation dot1Q 3
ip address 192.168.5.1 255.255.255.0
ip access-group 2 out
ip nat inside
interface GigabitEthernet0/0.4
encapsulation dot1Q 4
ip address 192.168.30.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.5
encapsulation dot1Q 5
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.6
encapsulation dot1Q 6
ip address 192.168.11.1 255.255.255.0
interface GigabitEthernet0/0.7
encapsulation dot1Q 7
ip address 192.168.20.1 255.255.255.0
ip access-group 3 out
interface GigabitEthernet0/0.8
encapsulation dot1Q 8
ip address 192.168.22.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.9
encapsulation dot1Q 9
ip address 192.168.40.1 255.255.255.0
ip access-group 4 out
ip nat inside
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.44.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1
ip address X.X.X.X 255.255.255.252
ip nat outside
duplex auto
speed auto
ip dhcp pool LeecherPool
   network 192.168.40.0 255.255.255.0
   default-router 192.168.40.1
   dns-server 192.168.40.1
ip dhcp pool ForklanPool
   network 192.168.30.0 255.255.255.0
   default-router 192.168.30.1
   dns-server 192.168.30.1
ip dhcp pool SeclanPool
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
   dns-server 192.168.10.1
ip dhcp pool SecwlanPool
   network 192.168.11.0 255.255.255.0
   default-router 192.168.11.1
   dns-server 192.168.11.1
ip dhcp pool SafelanPool
   network 192.168.20.0 255.255.255.0
   default-router 192.168.20.1
   dns-server 192.168.20.1
ip dhcp pool SafewlanPool
   network 192.168.22.0 255.255.255.0
   default-router 192.168.22.1
   dns-server 192.168.22.1
ip dhcp pool RoamerPool
   network 192.168.44.0 255.255.255.0
   default-router 192.168.44.1
   dns-server 192.168.44.1
ip name-server 204.130.255.3
ip route 0.0.0.0 0.0.0.0 Y.Y.Y.Y
ip dns server
access-list 1 deny   192.168.40.0 0.0.0.255
access-list 1 deny   192.168.44.0 0.0.0.255
access-list 1 deny   192.168.20.0 0.0.0.255
access-list 1 deny   192.168.22.0 0.0.0.255
access-list 1 permit any
access-list 2 deny   192.168.40.0 0.0.0.255
access-list 2 deny   192.168.44.0 0.0.0.255
access-list 2 deny   192.168.30.0 0.0.0.255
access-list 2 permit any
access-list 3 deny   192.168.40.0 0.0.0.255
access-list 3 deny   192.168.44.0 0.0.0.255
access-list 3 permit any
access-list 4 deny   192.168.20.0 0.0.0.255
access-list 4 deny   192.168.22.0 0.0.0.255
access-list 4 permit any
access-list 5 permit 192.168.5.0 0.0.0.255
access-list 5 permit 192.168.2.0 0.0.0.255
access-list 5 permit 192.168.30.0 0.0.0.255
access-list 5 permit 192.168.10.0 0.0.0.255
access-list 5 permit 192.168.11.0 0.0.0.255
access-list 5 permit 192.168.40.0 0.0.0.255
access-list 5 permit 192.168.44.0 0.0.0.255
ip nat inside source list 5 interface GigabitEthernet0/1 overload
end
As you can see, I have subinterfaces on the trunk, dhcp pools for those vlans, and access lists to filter traffic. Access lists are source based, and pointed "out" on destination subinterface. There is also "ip domain lookup" command that I issued, but is not seen in the configuration file (?).
Any help will be greatly appreciated!
Edwin Summers
Level 8
Level 8
Is the portion of the config you posted only from the 2800?  Have you sniffed traffic and are queries reaching the 2800 and being forwarded?
ip domain lookup is enabled by default, which is probably why it isn't appearing when you show the config.  If you turned it off (no ip domain-lookup), you should see the command in the config.
Yes, the config is only from the router. I am configuring the device remotely, and have on-site technician for some basic cabling etc, so I cant run Wireshark unfortunately. It would be a good troubleshooting though.
Do you think ACLs can be the problem?
If you the version of IOS on your router supports the feature you can use embedded packet capture to capture packets remotely on the router
http://www.cisco.com/en/US/docs/ios/netmgmt/configuration/guide/nm_packet_capture_ps6441_TSD_Products_Configuration_Guide_Chapter.html
As a test if you remove the outbound ACL from one on the sub-interfaces can you browse the Internet using DNS names?
Please remember to rate all posts that are helpful.
Have you confirmed if the router is resolving the names itself?
Can you ping something like yahoo.com and see if it comes back with an ip address?
