fiber uplinking NX5020 to NX7000
Rosa Ladeira
I intend to uplink NX5020 2 fiber ports to a NX7000 2 fiber ports running port-channel.
I have created on both sides:
interface port-channel10
  switchport mode trunk
  description NX7000 (SFP) <--> NX5000 (SFP)
I have configure fiber interfaces like this
interface Ethernet1/1
description description NX7000 (SFP) <--> NX5000 (SFP)
channel-group 10
no shutdown
interface Ethernet1/2
channel-group 10
no shutdown
Is there any specific fiber port on NX5020 to uplink to NX7000?
Rosa
2 Accepted Solutions
Partha Dasgupta
Hello Rosa,
There is no specific fiber port in N5K or N7K for configuring as uplink port.
as per the conf pasted , its looks like we have to enable feature lacp  and configure the port channel as
channel-group 10 mode active
This schould be done in both the devices (N7K and N5K)
Partha
Rosa,
yes , you can use it.
In contrast to a static link aggregation, LACP provides the following advantages:[8]
  • Even if one physical links fails, it will detect if the point-to-point connection is using a media converter, so that the link status at the switching port remains up. Because LACPDUs do not form a component of this connection, the link will be removed from the link aggregate. This ensures that packets will not be lost due to the failed link.
  • Both of the devices can mutually confirm the LAG configuration. With static link aggregation, errors in the configuration or wiring will often not be detected as quickly.
Partha
7 Replies 7
Partha Dasgupta
Hello Rosa,
Partha
Ooopss!
NX7000 is running version5.2(7).
By now it has fiber trunk connection with 4 Cisco6509 boxes running fine, feature lacp is disables.
NX5020 is running version 4.0(1a)N2(1).
It is being deployed.
Version 4 does not have any feature.
So what do you suggest - try and see ?
Rosa
Rosa,
You can verify the what are the feature available in  4.0(1a)N2(1). using show feature. I believe it will have feature lacp if it supports vpc
If feature lacp not available in N5K, you can give try specifying channel group 10 mode on ( I believe u might have already done it)
Partha
Partha as NX7000 has feature lacp disabled can I use "channel group 10 mode on " on both sides ?
Qhat are the benefis of using lacp ?
Rosa
Rosa,
Partha
Partha lacp is realy great!
What a pity, but must upgrade nx-os.
Rosa
It works fine !
