nexus 5000 code levels
glen.grant
  Getting ready to install new 5000's and they are running 5.1.3.n2 .  This seems to be like 2-3 levels behind do most of you  try to run the latest versions which is like 6.0.2 version at this point ?
Reza Sharifi
Just to be safe, I usually don't install the latest version and use a version earlier before the last.
Cisco's official recommendation (and what we are generally following successfully with our clients) is 5.2(1)N1(4)
Reference.
I'd only go with 6.0 if you had specific needs to use features introduced with 6.0.
