figuring out the cause of a switch reboot?
baselzind
Level 6
Level 6
i found out that some of my switches restarted in the weekend "3560G-48PS and a WS-C4507R" , i was asked to figure out why they restarted , i checked the temps , cpu and power and "show logging" and everything is okey , so im wondering is it possible to find out the reason of a switch reboot or not , and if so how?
"the 4507" have a UPS connected so it rules out power outage it also have two supervisors modules???
I don't think so.  Look at the uptime of both outputs.  They're just 28 minutes apart.   So maybe there was a power outage but it took too long and the UPS ran out of juice.
5 Replies 5
Leo Laohoo
Post the complete output to the following commands:
1.  sh version; and
2.  dir
for the first one :
#show version
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASEK9-M), Versi on 12.2(50)SG1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 09-Feb-09 20:40 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x11C294C8
ROM: 12.2(31r)SGA1
Pod Revision 14, Force Revision 31, Tie Revision 32
uptime is 20 hours, 55 minutes
Uptime for this control processor is 20 hours, 55 minutes
System restarted at XXX
System image file is "bootflash:cat4500-ipbasek9-mz.122-50.SG1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4507R (MPC8540) processor (revision 13) with 524288K bytes of memory.
Processor board ID FOX1235G3BC
MPC8540 CPU at 800Mhz, Supervisor V-10GE
Last reset from PowerUp
2 Virtual Ethernet interfaces
104 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
#dir
Directory of bootflash:/
2 -rwx 15728568 Apr 13 2009 09:27:37 +03:00 cat4500-ipbasek9-mz.122-50.SG1.bin
61341696 bytes total (33484992 bytes free)
for the second :
Cisco IOS Software, C3560 Software (C3560-IPBASEK9-M), Version 12.2(55)SE10, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 11-Feb-15 11:34 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02D00000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
uptime is 1 day, 20 hours, 27 minutes
System restarted at
System image file is "flash:c3560-ipbasek9-mz.122-55.SE10.bin"
export@cisco.com.
cisco WS-C3560G-48PS (PowerPC405) processor (revision F0) with 131072K bytes of memory.
Last reset from power-on
52 Gigabit Ethernet interfaces
512K bytes of flash-simulated non-volatile configuration memory.
Model revision number : F0
Motherboard revision number : C0
Model number : WS-C3560G-48PS-S
Top Assembly Revision Number : D0
Version ID : V05
CLEI Code Number : CNMWW00ARC
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
* 1 52 WS-C3560G-48PS 12.2(55)SE10 C3560-IPBASEK9-M
Configuration register is 0xF
Directory of flash:/
2 -rwx 3684 Aug 1 2016 11:26:16 +03:00 vlan.dat
3 -rwx 5 Aug 4 2016 15:26:48 +03:00 private-config.text
4 -rwx 11773637 Aug 4 2016 14:58:37 +03:00 c3560-ipbasek9-mz.122-55.SE10.bin
5 -rwx 36434 Aug 4 2016 15:26:48 +03:00 config.text
7 drwx 192 Mar 1 1993 03:08:39 +03:00 c3560-ipbase-mz.122-35.SE5
465 -rwx 1048 Mar 1 1993 03:02:54 +03:00 multiple-fs
32514048 bytes total (11644416 bytes free)
Possible power outage.
System restarted at
Contents of the flash is absent of the sub-directory "crashinfo" so I do NOT believe there was a crash.
yes actually it seems the second one had a power outage but the first one "the 4507" have a UPS connected so it rules out power outage it also have two supervisors modules???
