filtering ip from accessing router 2911 for remote management
i have router 2911
pub ip: 121.97.65.61-74
interface gigabitethernet 0/1
ip address 121.97.65.61/28
no ip proxy-arp
no ip redirects
ip virtual-reassembly
duplex full
speed 1000
____________
firewall ip:
ip: 121.97.65.62
sm: 255.255.255.240
d-gateway or static ip route: 121.97.65.61
____________
i need to remote my router intenede only no this ip range:
121.97.65.61 - .74/28
and other ip will drop/kick/disconnected automatically
how to implement this on access list
anyone can solve and be part of my network setup
your help highly appreciated
2 Accepted Solutions
Kai Onken
If I've understood you correct, you want ony remote access to router for the IP Range 121.97.65.61 to 121.97.65.74, right?
So try this
ip access-list standard VTY
  remark "Remote access"
  101 permit 121.97.65.61
  102 permit 121.97.65.62
  103 permit 121.97.65.63
  104 permit 121.97.65.64
  105 permit 121.97.65.65
  106 permit 121.97.65.66
  107 permit 121.97.65.67
  108 permit 121.97.65.68
  109 permit 121.97.65.69
  110 permit 121.97.65.70
  111 permit 121.97.65.71
  112 permit 121.97.65.72
  113 permit 121.97.65.73
  114 permit 121.97.65.74
exit
line vty 0 15
  access-class VTY in
exit
The problem is, that .61 /28 is no default IP network and because of this, you have to use single IP Addresses.
Kind regards
Kai
Pasting a VPN configuration could be a little bit difficult. Because, I don't know which IOS, VPN Client, Client Platform, etc. you use.
Once I worte a VPN Setup for Apple iPhone and iPad usage, maybe this will help you a little.
https://supportforums.cisco.com/message/3835229#3835229
Kind regards
Kai
6 Replies 6
Kai Onken
So try this
exit
line vty 0 15
  access-class VTY in
exit
Kind regards
Kai
Hi Kai
your config doing fine however another problem occurs
inside of the network i can access via remote
but
outside office, home, internet cafe/shop, my friends house, i can't access my router.. why?
by the way
here's ISP ip range gave:
wan ip: 125.212.12.252
isp side: 125.212.12.253
client side: 125.212.12.254
sub mask: 255.255.255.252
public ip: 121.97.65.61 - .74 / 28
on my router:
all offices access with the ip route overload: 125.212.12.253
all server acess with the ip route overload statement above: ip nat inside source-list SERVERS interface gigabitethernet 0/1 overload
with the ip route with this:
ip route 0.0.0.0 0.0.0.0 125.212.12.253
ip nat inside source-list OFFICES interface gigabitethernet 0/0 overload
_________
router:
ip address 125.212.12.254 255.255.255.252
no ip redirects
no ip proxy-arp
ip virtual reassembly
no cdp enable
duplex full
speed auto
the configuration I posted, does anythig you requested. If you want to access the router via the WAN interface, I've to know serveral things and I also have to ask some questions.
1. Is the IP Address, which you receive a static one or dynamic?
         If yes, you'll have an quiet simple way.
         If no, you have to configure something like DynDNS, so that you can reach the WAN Interface from everywhere
2. Does your places outside the office, e.g home, internet cafe/shop, my friends house, have static IP Addresses?
         If yes, you can add them to the access list
         If no, you have a problem, because then you have allways to replace the 'old' IP Address with the 'new' on
         A possible soluttion could be the setup of a VPN Server at you router. But than you would have another problem:
                1. You need a static IP Address or e.g. a DynDNS entry
                2. Than you have only to add the VPN network to your access list.
                3. You would be able to install a VPN Client at you home computer, your friends computer but I think you would't be allowed to install a VPN Client on an Internet shops computer.
Kind regards
Kai
-> yes, static written above ISP gave that
-> yes, static . 124.45.65.201/24
1. i have static if you want a vpn setup on a router, but for me know how?
2. how to add, i even dont know how to create one.
3. installing vpn client is not a problem, i have on my own gear and i bring this where i am
and if you give me 1 shot on creating vpn server on my router 2911, and some other config ,
Kind regards
Kai
Hi Kai,
very helpful link from you
