Finding switch & port using MAC add
let say in the building of 6 level
level 6 is the core switch
level 5 - 1 is access switch
i need to find mac address of a PC ended with .ab01
i know the 'sh mac add-table | in ab01, it will show trunk port
how can i pinpoint to exactly the access switch & port of the PC ??
because when i see trunk port, i stuck and don't know how to move foward
maybe using the combo of cdp neigh detail??
Please help & suggest
If you have executed the command show mac address-table | inc abcd on the Core switch it will show the port/interface where the MAC address is being learned so you can include that port/interface on the command below:
Imagine the show mac address-table | inc abcd provide that MAC is being learned through the interface g1/10
show cdp neig <port/interface> details
example
show cdp nei g1/10 details
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
7 Replies 7
Julio E. Moisa
You can use
show mac address-table | include <mac address or the last 4 values> ; (no arrows) it can point to the trunks so you can use show cdp neig <interface> details to find the IP of the next switch as you mentioned.
example: show mac address-table | include ab01
My recommendation is run it on the Core / Distribution switches first. You cannot find the PC directly unless you know the switch, so you need find it switch by switch starting from the Core.
Hope it is useful
Hi Julio,
Yes,that what I'm doing but at the core/distribution when i enter
show cdp neig details , it will show all the access switch for every floor (assume each floor more than 1 switch)
i still can't relate how to pintpoint to the exact access switch
unless i 'sh mac address-table | in ab01 on every acess switch
show cdp neig <interface> details : for the <interface>, which interface?
example
Hi Julio,
Thanks. i will need to test again & see the output
because, during my previous test , the output of show mac address-table | inc abcd = is gi2/0/49 ( this is at core)
and gi2/0/49 = is trunk port
i hv to give a try for 'sh cdp nei gi2/0/49 deta
Yeah,
tested and got it.
Reza Sharifi
At the core, you can use "sh ip ar | inc .ab01" this will tell you what vlan has that mac address and if you have vlans per floor, you can go to that specific switch for that floor and use "sh mac add-table | in ab01" and find the mac address.  If you have one vlan for all floors than you would have to go to every floor to find it.  The easiest way to do this is to use a free software called "switchmap" It inventory you switches once or twice a day (you can do more than 2 times if you want) and create a map of all the mac addresses, IP address, ports, descriptions, speed, duplex, etc.. You can than easily search for the mac address and find all the info you want about that port in less 30 seconds.
mamin42618
Community Member
There is another situation associated to this topic; if someone knows the solution and like to share here;
well, I was reported an end user disconnection, with the ip address mentioned. My SRX could track the MAC address for me using sh arp | m a.b.c.d
I tried to trace the Mac address at my core switch using sh mac address-tab | i 1234.5678.90ab
It didn’t return any entry 😞
possibly host was down for a long time such as 10 mins or so and mac entry was updated meanwhile.
My question is , in such situation, how can I figure out, which switch & port , the host is attached to? Coz I need to make sure the status of my physical port is healthy. Please advise, as per best of your experience. Thanks.
