FIPS: Flash Key Check on Cisco 2960-S switch
leesince004
Hello there,
we have recently acquired few used Cisco 2960-S series switches, and we are curious about something.
While the switches are booting, we are getting a message after flashfs initialization.
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled.
Does this affect the switch in any way? It boots normally right after, all the test checks are passed so we are wondering what is that message.
Thank you in advance!
marce1000
  - Nothing to worry about , fips refers to enhanced security standards , the switch will be fine without it ,
 M.
marce1000
 M.
Hi @marce1000 , thanks for the quick reply!
One quick question regarding the 2960-S switches.
When we go into ROMMON to factory reset one of our switches, after the firmware boot, we get multiple MBIST fails but the switch boots normally. If we reboot it without going into ROMMON, there are no fails and the switch seems to be working normally.
Below is the provided console logs.
The system has been interrupted prior to initializing the
flash filesystem.  The following commands will initialize
the flash filesystem, and finish loading the operating
system software:
    flash_init
    boot
switch: flash_init
Initializing Flash...
mifs[2]: 10 files, 1 directories
mifs[2]: Total bytes     :    1806336
mifs[2]: Bytes used      :     612352
mifs[2]: Bytes available :    1193984
mifs[2]: mifs fsck took 1 seconds.
mifs[3]: 0 files, 1 directories
mifs[3]: Total bytes     :    3870720
mifs[3]: Bytes used      :       1024
mifs[3]: Bytes available :    3869696
mifs[3]: mifs fsck took 2 seconds.
mifs[4]: 5 files, 1 directories
mifs[4]: Total bytes     :     258048
mifs[4]: Bytes used      :       9216
mifs[4]: Bytes available :     248832
mifs[4]: mifs fsck took 0 seconds.
mifs[5]: 5 files, 1 directories
mifs[5]: Total bytes     :     258048
mifs[5]: Bytes used      :       9216
mifs[5]: Bytes available :     248832
mifs[5]: mifs fsck took 0 seconds.
 -- MORE --
mifs[6]: 565 files, 20 directories
mifs[6]: Total bytes     :   57931776
mifs[6]: Bytes used      :   15288320
mifs[6]: Bytes available :   42643456
mifs[6]: mifs fsck took 30 seconds.
...done Initializing Flash.
switch: dir flash:
Directory of flash:/
    2  drwx  512       <date>               online_diag
    3  -rwx  1918      <date>               private-config.text
    4  -rwx  3096      <date>               multiple-fs
    5  -rwx  2632      <date>               config.text
    6  drwx  512       <date>               c2960s-universalk9-mz.122-55.SE7
42643456 bytes available (15288320 bytes used)
switch: del flash:config.text
Are you sure you want to delete "flash:config.text" (y/n)?y
File "flash:config.text" deleted
switch: boot
Loading "flash:/c2960s-universalk9-mz.122-55.SE7/c2960s-universalk9-mz.122-55.SE7.bin"
Initializing flashfs...
Using driver version 1 for media type 1
mifs[3]: 10 files, 1 directories
mifs[3]: Total bytes     : 1806336
mifs[3]: Bytes used      : 612352
mifs[3]: Bytes available : 1193984
mifs[3]: mifs fsck took 0 seconds.
mifs[3]: Initialization complete.
mifs[4]: 0 files, 1 directories
mifs[4]: Total bytes     : 3870720
mifs[4]: Bytes used      : 1024
mifs[4]: Bytes available : 3869696
mifs[4]: Initialization complete.
mifs[5]: Initialization complete.
mifs[6]: 5 files, 1 directories
mifs[6]: Total bytes     : 258048
mifs[6]: Bytes used      : 9216
mifs[6]: Bytes available : 248832
mifs[6]: mifs fsck took 0 seconds.
mifs[6]: Initialization complete.
mifs[7]: 564 files, 20 directories
mifs[7]: Total bytes     : 57931776
mifs[7]: Bytes used      : 15284736
mifs[7]: Bytes available : 42647040
mifs[7]: mifs fsck took 0 seconds.
mifs[7]: Initialization complete.
...done Initializing flashfs.
POST: MA BIST : BeginYeti2S88gMdioWr: Unknown status for write operation
***ERR: S88G FC 1   MBIST Unload Activity
***ERR: S88G FC 1   MBIST failed
***ERR: S88G DP Sg1 MBIST Unload Activity
***ERR: S88G DP Sg1 MBIST failed
***ERR: S88G DP Xg1 MBIST Unload Activity
***ERR: S88G DP Xg1 MBIST failed
***ERR: S88G NI 1   MBIST Unload Activity
***ERR: S88G NI 1   MBIST failed
***ERR: S88G FC 0   MBIST Unload Activity
***ERR: S88G FC 0   MBIST failed
***ERR: S88G DP Sg0 MBIST Unload Activity
***ERR: S88G DP Sg0 MBIST failed
***ERR: S88G DP Xg0 MBIST Unload Activity
***ERR: S88G DP Xg0 MBIST failed
***ERR: S88G NI 0   MBIST Unload Activity
***ERR: S88G NI 0   MBIST failed
***ERR: S88G UPB    MBIST Unload Activity
***ERR: S88G UPB    MBIST failed
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
extracting front_end/front_end_ucode_info (86 bytes)
Waiting for Stack Master Election...
POST: Thermal, Fan Tests : Begin
POST: Thermal, Fan Tests : End, Status Passed
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
POST: EMAC Loopback Tests : Begin
POST: EMAC Loopback Tests : End, Status Passed
Election Complete
Switch 1 booting as Master
Waiting for Port download...Complete
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960S-48TS-L (PowerPC) processor (revision B0) with 131072K bytes of memory.
Processor board ID FOC1447Y36V
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : EC:C8:82:D9:2E:80
Motherboard assembly number     : 73-11909-06
Power supply part number        : 341-0327-02
Motherboard serial number       : FOC14432SRA
Power supply serial number      : DCA1441P1CW
Model revision number           : B0
Motherboard revision number     : A0
Model number                    : WS-C2960S-48TS-L
Daughterboard assembly number   : 73-11933-04
Daughterboard serial number     : FOC144743WF
System serial number            : FOC1447Y36V
Top Assembly Part Number        : 800-30950-02
Top Assembly Revision Number    : A0
Version ID                      : V02
CLEI Code Number                : COMGF00ARB
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C2960S-48TS-L   12.2(55)SE7           C2960S-UNIVERSALK9-M
Thanks in advance!
