Firmware Upgrade
fb_webuser
Level 11
Level 11
im guessing there is zero chance of a firmware upgrade for the SRP527W to support more usb devices is there?
Posted by WebUser Alexander Bianco from Cisco Support Community App
Gregory Snipes
Level 11
Level 11
The USB port on the SRP527W is only there to support a wireless modem backup. If you are asking whether Cisco may release a firmware to support a wider range of wireless modems, the answer is maybe. If you are asking weather Cisco may release an update that allows the use of other equipment, like printers/hard drives, that's a definite no. Cisco is not in the habit of adding that kind of functionality with firmware updates.
