First PING or TCP Session timeout or latency
Tbaror123
Hello All,
I am trying to to identify issue on network that consist Catalyst 4510R +E , having two  L3 Vlan's.
172.28.0.0/16 <<>>10.151.1.0/24
We have application that connecting to a server that reside on 10.151.1.124 tcp port 5080 , and thee issue is on machine fresh boot the clients first time can't connect second attempt connect  and further connecting without an issue
same symptom with ping shows as follows below
Currently i don't have yet the switch config , but i would be glad to have some direction to starting looking for , what could cause or setting in the switch this issues?
Please advice
Pinging 10.151.1.124 with 32 bytes of data:
Infinite iterations (warmup 1) ping test:
Error pinging 10.151.1.124:
Request timed out.
Reply from 10.151.1.124: 0.42ms
Reply from 10.151.1.124: 0.48ms
Reply from 10.151.1.124: 0.81ms
Reply from 10.151.1.124: 0.53ms
Reply from 10.151.1.124: 1.08ms
Reply from 10.151.1.124: 0.90ms
Reply from 10.151.1.124: 1.06ms
Reply from 10.151.1.124: 0.49ms
  Sent = 9, Received = 9, Lost = 0 (0% loss),
  Minimum = 0.42ms, Maximum = 1.08ms, Average = 0.70ms
Mark Malone
sounds like an arp issue , thats what usually happens when the first ping is dropped then works , the default return time i think is only few seconds so if the far end takes longer to return the reply it will see it as a dropped ping , hard to tell woithout seeing some info but i would try set static arp and see if that makes a difference just for that ip
