05-01-2018 04:11 AM - edited 03-08-2019 02:51 PM
Hello!
I am configure a WAN interface at now and also one of the lan interface for managment computer.
Now i am need to configure to send internet access router -> 48 port switch -> 15x 24 port switch -> 266 devices.
Already configured i thnik because it work:
Embedded-Service-Engine0/0 is administratively down, line protocol is down Hardware is Embedded Service Engine, address is 0000.0000.0000 (bia 0000.0000.0000) MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/64/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts (0 IP multicasts) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 unknown protocol drops 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out
NVI0 is up, line protocol is up
Hardware is NVI
Internet address will be negotiated using IPCP
MTU 1514 bytes, BW 56 Kbit/sec, DLY 5000 usec,
Encapsulation UNKNOWN, loopback not set
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
GigabitEthernet0/0/0 is up, line protocol is up
Hardware is EHWIC-1GE-SFP-CU, address is 707d.b9e9.91a8 (bia 707d.b9e9.91a8)
Description: ISP
Internet address is 203.91.x.x/30
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Auto Duplex, Auto Speed, media type is LX
output flow-control is XON, input flow-control is XON
Last input 00:00:16, output 00:00:09, output hang never
5 minute input rate 4167000 bits/sec, 509 packets/sec
5 minute output rate 3651000 bits/sec, 491 packets/sec
1043451 packets input, 1141347190 bytes, 0 no buffer
Received 1451 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
987750 packets output, 818498244 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
1158 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/1 is up, line protocol is up
Hardware is CN Gigabit Ethernet, address is 707d.b9e9.91a1 (bia 707d.b9e9.91a1)
Description: NabohuOPS
Internet address is 192.168.5.1/24
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 10/255, rxload 9/255
Full Duplex, 100Mbps, media type is RJ45
output flow-control is unsupported, input flow-control is unsupported
Last input 00:00:07, output 00:00:06, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 4293
5 minute input rate 3657000 bits/sec, 491 packets/sec
5 minute output rate 4134000 bits/sec, 506 packets/sec
754665 packets input, 615303676 bytes, 4293 no buffer
Received 90 broadcasts (0 IP multicasts)
752581 packets output, 809230232 bytes, 0 underruns
5 lost carrier, 0 no carrier, 0 pause output
Now i need to configure this interface for a this all switchs and devices:
GigabitEthernet0/0 is down, line protocol is down Hardware is CN Gigabit Ethernet, address is 707d.b9e9.91a0 (bia 707d.b9e9.91a0 ) Description: $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$ Internet address is 10.10.10.1/25 MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Auto Duplex, Auto Speed, media type is RJ45 output flow-control is unsupported, input flow-control is unsupported ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:14:19, output 00:12:49, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1087 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 231209 packets input, 205323567 bytes, 1087 no buffer Received 224 broadcasts (0 IP multicasts) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog, 0 multicast, 0 pause input 284499 packets output, 322094409 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 unknown protocol drops 0 babbles, 0 late collision, 0 deferred 7 lost carrier, 0 no carrier, 0 pause output 0 output buffer failures, 0 output buffers swapped out
Of course i need help to choose good IP addressing / subnet masks for this LAN switch party network.
If any one help me with this configuration i will invite to Mongolia trip :)
By the way router is connected to switch with 1000base-T cable RJ45 and also this switch too support gigabitethernet port. Other switches only megabitethernet, devices too.
Solved! Go to Solution.
05-02-2018 04:46 AM
Solved myself.
05-02-2018 04:46 AM
Solved myself.
