FIXED: 9300-48 %FMFP-3-OBJ_DWNLD_TO_DP_FAILED: Switch 2 R0/0:
Fulvio Ferreira
Hello
I recently installed one issue with a C9300-48UXM - 16.12.05b and it started  to show the following log messages:
Oct 24 07:00:19.001: %FMFP-3-OBJ_DWNLD_TO_DP_FAILED: Switch 2 R0/0: fman_fp_image: WRClient 0x1fc99b8a download to DP failed
Oct 24 07:00:48.846: %FMFP-3-OBJ_DWNLD_TO_DP_FAILED: Switch 1 R0/0: fman_fp_image: WRClient 0x1fc99b8a download to DP failed
Oct 24 07:00:49.016: %FMFP-3-OBJ_DWNLD_TO_DP_FAILED: Switch 2 R0/0: fman_fp_image: WRClient 0x1fc99b8a download to DP failed
It looks like switch is trying to create/change/delete the mac-address related to this code: 0x1fc99b8a. This mac-address 08cc.6828.1c40 has been learned from Interface Te1/1/1 only:
silaclast008-dc-1ba44#sh plat soft wired-client sw 1 f0 id 0x1fc99b8a
MAC address : 08cc.6828.1c40
Physical interface dpidx : 0x0000003d
Authentication state : L3 Auth
VLAN ID : 0
Open Access : Yes
Client Forward : Yes
Dynamic policy template :
Client AOM Object ID : 18300436
Client AOM Object Status : Modify/delete-failed
FWD AOM Object ID : 0
FWD AOM Object Status : Pending-issue
BIND AOM Object ID : 0
BIND AOM Object Status : Pending-issue
silaclast008-dc-1ba44#sh plat soft wired-client sw 2 f0 | in Create-failed
0x10fb974c 08cc.a7ad.fdc1 Yes Yes Create-failed
0x110aae08 d477.983b.3bd2 Yes Yes Create-failed
0x12cbce93 5017.ff88.8441 Yes Yes Create-failed
0x149fac82 0004.f2e8.b156 Yes Yes Create-failed
0x183b1725 c40a.cbaf.80c1 Yes Yes Create-failed
0x1afeee20 34db.fd9c.1741 Yes Yes Create-failed
0x1d22448e c40a.cbac.9241 Yes Yes Create-failed
0x1fc99b8a 08cc.6828.1c40 Yes Yes Create-failed
silaclast008-dc-1ba44#sh mac add add 08cc.6828.1c40
Mac Address Table
Vlan Mac Address Type Ports
2134 08cc.6828.1c40 DYNAMIC Te1/1/1
3008 08cc.6828.1c40 DYNAMIC Te1/1/1
I've already opened a TAC case and Cisco Engineer suggested to Disable “access-session monitor” on the uplinks from Uplink Interfaces, but these log messages are still happening.
Does anyone have or had this same issue?
balaji.bandi
that is the part of BUG  so tac suggests an alternative, if you disable it, check show access-session see any changes.
write the config and reload and test it.
if possible upgrade to any latest IOS XE and test it.
also see another BUG
BB
Fulvio Ferreira
I applied no access-session monitor on both Uplink interfaces and switch stopped logging messages.
Glad to know it was suppressed in the logs, we mark this as resolved.(thank you for your feedback)
BB
