05-23-2023 01:07 PM
Type: SW_MATM-4-MACFLAP_NOTIF
interface GigabitEthernet1/0/7
description COPPER Startech VDSL
switchport mode trunk
priority-queue out
mls qos trust dscp
spanning-tree portfast edge trunk
interface GigabitEthernet1/0/8
description ACCESS POINT VLAN 1 + 403
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
I keep having these Errors on a Cisco 3750, only thing on this switch is APs.
Could this be why the AP are so hit or miss or keep messing up and If so what would be a good way to fix this?
Thank you
05-23-2023 01:14 PM
This normal if wifi client do roaming
You can use
No mac address notify mac move
05-23-2023 01:28 PM - edited 05-23-2023 01:28 PM
It appears that you have some sort of loop on the network, because the same MAC address shows up on multiple physical ports. Are all the APs connected to this switch using a single link or multiple? Are you using any hubs anywhere on the network?
Also, on your trunk ports to APs, it is always a good idea to allow only the vlans that need to be on the trunk port and not all vlans.
switchport trunk allowed vlan x, y, z
