Showing results forĀ
Search instead forĀ
Did you mean:Ā
Flapping interfaces
ankugarg
Level 3
Level 3
I have flapping mac address in layer 2 ring topology...Is there any easy and straight forward way to determine who is triggering this  mac address..thanks.
2 Accepted Solutions
Reza Sharifi
Not really.  You need to trace the mac address and figure out what switch the device is connect it to.  Is it coming from a server, PC, etc...?  If it is from a server, is NIC teaming configured on the server?  Need to know in what vlan the  MAC is flapping.  Since it is a layer-2 environment, you also need to make sure there is no loop in your network.
If you have the MAC address you can check WHAT the device is using Coffer.
Next, I shut down the redundant link and trace where the MAC address is "living".  Then I'd take a metal pole to the owner of the device and bash his/her head to a pulp.
6 Replies 6
Reza Sharifi
Hmm...thats what i suspected..thanks
Leo Laohoo
Thanks for the ratings.
NOTE:  In my last post, the last sentence is meant as a joke and not typically a solution.
Good,you told me early...I was looking for a metal pole
On a serious note,that Coffer thing is helpful..thanks.
I have MAC flapping issue in my network due to NIC teaming configured on the server.
I found the issue and rectified because of this Mr.Reza Sharifi update.
Thank you Mr.Reza Sharifi for sharing your knowledge.
