Cisco 1921 Client Access wont work, only with ipv4 Part 2
macgyver1988
THIS IS PART 2, Because the olds too long
this is my running-config ....
but theres one problem:
by adding on GigabitEthernet0/1
ipv6 traffic-filter WAN_OUTSIDE_INv6 in
i wont get any DHCP Adresses on my lan Interfaces on the mac clients....
but when typing manuell those adresses to the clients....all seems working fine...
what i made wrong?But i also geht on cisco and on mac clients ipv6 addresses
This is my running_config:
Cisco1921#show running-config
Building configuration...
Current configuration : 7746 bytes
! Last configuration change at 09:58:05 CET Thu Dec 1 2016 by user4754
version 15.5
service timestamps log datetime localtime
service password-encryption
hostname Cisco1921
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 10
enable secret 5 XXXXX
no aaa new-model
ethernet lmi ce
clock timezone CET 1 0
clock summer-time CEST recurring last Sun Mar 2:00 last Sun Oct 3:00
ip dhcp binding cleanup interval 600
ip dhcp excluded-address 192.168.50.170 192.168.50.254
ip dhcp excluded-address 192.168.50.1 192.168.50.153
ip dhcp pool Internal Network
 network 192.168.50.0 255.255.255.0
 domain-name soho.intern
 default-router 192.168.50.2
 dns-server 192.168.50.2
ip domain name soho.intern
ip name-server 212.18.0.5
ip name-server 212.18.3.5
ip name-server 2001:A60::53:1
ip name-server 2001:A60::53:2
ip inspect name Firewall udp
ip inspect name Firewall sip
ip inspect name Firewall rtsp
ip inspect name Firewall ftp
ip inspect name Firewall icmp
ip inspect name Firewall pptp
ip inspect name Firewall tcp
ip inspect name Firewall https
ip inspect name Firewall pop3s
ip inspect name Firewall smtp
ip inspect name Firewall imaps
ip cef
ipv6 general-prefix MyLocals FD00:1234:5678::/48
ipv6 general-prefix MyLocals FD00:8765:4321::/48
ipv6 unicast-routing
ipv6 dhcp pool NODE-DHCPV6
 prefix-delegation pool NODE-PD lifetime 1800 60
 dns-server 2001:A60::53:1
 dns-server 2001:A60::53:2
ipv6 inspect name inspectv6 udp
ipv6 inspect name inspectv6 ftp
ipv6 inspect name inspectv6 icmp
ipv6 inspect name inspectv6 tcp
ipv6 multicast-routing
ipv6 cef
ipv6 cef accounting per-prefix
cts logging verbose
crypto pki trustpoint TP-self-signed-XXXX
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-XXXX
 revocation-check none
 rsakeypair TP-self-signed-XXX
crypto pki certificate chain TP-self-signed-XXXX
 certificate self-signed 01
  XXXXXXX
        quit
license udi pid CISCO1921/K9 sn FXXXX
username user4754 password 7 XXXXX
redundancy
controller VDSL 0/1/0
 firmware filename flash:VA_A_39m_B_38u_24h.bin
ip tcp synwait-time 5
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description NETWORK INTERN
 ip address 192.168.50.2 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 ip tcp adjust-mss 1452
 duplex auto
 speed auto
 ipv6 address MyLocals ::1/64
 ipv6 address NODE-PD ::1/64
 ipv6 enable
 ipv6 nd other-config-flag
 ipv6 dhcp server NODE-DHCPV6
 ipv6 inspect inspectv6 out
interface ATM0/1/0
 no ip address
 no atm ilmi-keepalive
interface ATM0/1/0.1 point-to-point
 pvc 1/32
  bridge-dot1q encap 40
  pppoe-client dial-pool-number 1
interface Ethernet0/1/0
 no ip address
 no ip route-cache
interface Ethernet0/1/0.40
 encapsulation dot1Q 40
 no ip route-cache
 pppoe enable group global
interface GigabitEthernet0/0/0
 description NETWORK VOIP
 no ip address
interface GigabitEthernet0/0/1
 no ip address
interface GigabitEthernet0/0/2
 no ip address
interface GigabitEthernet0/0/3
 no ip address
interface Vlan1
 no ip address
interface Dialer0
 description VDSL Einwahl Interface to ISP MNET
 mtu 1492
 ip address negotiated
 ip access-group 111 in
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 ip inspect Firewall out
 encapsulation ppp
 dialer pool 1
 dialer idle-timeout 1800 inbound
 dialer-group 1
 ipv6 address FE80::179:1 link-local
 ipv6 address NODE-PD ::FF:0:0:0:1/128
 ipv6 address autoconfig default
 ipv6 enable
 ipv6 mtu 1492
 no ipv6 redirects
 no ipv6 unreachables
 ipv6 dhcp client pd NODE-PD rapid-commit
 ipv6 verify unicast reverse-path
 ipv6 traffic-filter WAN_INSIDE_OUTv6 out
 ipv6 virtual-reassembly in
 no keepalive
 ppp authentication pap chap callin
 ppp chap hostname XXXXXX@mdsl.mnet-online.de
 ppp chap password 7 XXXXX
 ppp ipcp dns request
 ppp ipcp mask request
 ppp ipcp route default
 no cdp enable
ip forward-protocol nd
ip http server
ip http secure-server
ip dns server
no ip nat service sip udp port 5060
ip nat inside source list 101 interface Dialer0 overload
dialer-list 1 protocol ipv6 permit
ipv6 route ::/0 Dialer0
access-list 101 permit ip 192.168.50.0 0.0.0.255 any
access-list 111 permit icmp any any administratively-prohibited
access-list 111 permit icmp any any echo-reply
access-list 111 permit icmp any any packet-too-big
access-list 111 permit icmp any any time-exceeded
access-list 111 permit icmp any any unreachable
access-list 111 permit udp any eq domain any
access-list 111 permit tcp any eq domain any
access-list 111 permit udp any eq ntp any
access-list 111 permit gre any any
access-list 111 permit udp any eq bootps any
access-list 111 permit udp any any eq 546
access-list 111 permit udp any eq 5060 any
access-list 111 deny   ip any any log
ipv6 access-list BLOCKv6
 deny ipv6 any any log-input
ipv6 access-list WAN_INSIDE_OUTv6
 sequence 5 permit ipv6 host 2001:A60::53:1 any
 sequence 6 permit ipv6 host 2001:A60::53:2 any
 sequence 10 permit icmp any any
 permit tcp any any
 permit udp any any
 sequence 100 deny ipv6 any any log-input
ipv6 access-list WAN_OUTSIDE_INv6
 sequence 10 permit icmp any any nd-na
 sequence 11 permit icmp any any nd-ns
 sequence 12 permit udp any any eq 546
 sequence 20 permit icmp any any
 sequence 40 permit tcp any any established
control-plane
line con 0
 logging synchronous
 login local
 transport preferred none
line aux 0
line 2
 no activation-character
 no exec
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password 7 XXXXXX
 ipv6 access-class BLOCKv6 in
 login local
 transport input telnet ssh
scheduler allocate 20000 1000
end
Cisco1921#
And this is my LOG:
And this is my Log:
Cisco1921#ena6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied tcp 2001:A61:3135:D500:DD3A:909A:4044:64A9(50260) (GigabitEthernet0/1 a820.6652.4e84) -> 2400:CB00:2048:1::C629:D6B8(80), 4 packets
*Dec  1 10:06:47: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(56237) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:1(53), 1 packet
*Dec  1 10:06:48: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied tcp 2001:A61:3135:D500:DD3A:909A:4044:64A9(50261) (Gigab
Cisco1921#enaitEthernet0/1 a820.6652.4e84) -> 2400:CB00:2048:1::C629:D6B9(80), 4 packets
*Dec  1 10:06:48: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(58969) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:2(53), 1 packet
*Dec  1 10:06:48: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied tcp 2001:A61:3135:D500:DD3A:909A:4044:64A9(50262) (GigabitEthernet0/1 a820.6652.4e84) -> 2400:CB00:2048:1::C629:D7B9(80), 4 packets
Cisco1921#enaCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(64617) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:2(53), 1 packet
*Dec  1 10:06:50: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied tcp 2001:A61:3135:D500:DD3A:909A:4044:64A9(50263) (GigabitEthernet0/1 a820.6652.4e84) -> 2400:CB00:2048:1::C629:D6BB(80), 4 packets
*Dec  1 10:06:50: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(54898) (GigabitEthernet
Cisco1921#ena0/1 a820.6652.4e84) -> 2001:A60::53:2(53), 1 packet
*Dec  1 10:06:50: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied tcp 2001:A61:3135:D500:DD3A:909A:4044:64A9(50264) (GigabitEthernet0/1 a820.6652.4e84) -> 2400:CB00:2048:1::C629:D7B8(80), 4 packets
*Dec  1 10:06:50: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(56237) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:2(53), 1 packet
Cisco1921#ena
*Dec  1 10:06:53: %SEC-6-IPACCESSLOGP: list 111 denied tcp 79.115.63.130(11820) -> 188.174.64.53(23), 1 packet
Cisco1921#ena
*Dec  1 10:07:30: %SEC-6-IPACCESSLOGP: list 111 denied tcp 222.102.242.30(51452) -> 188.174.64.53(23), 1 packet
Cisco1921#ena
*Dec  1 10:07:51: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(54299) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:1(53), 1 packet
*Dec  1 10:07:51: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(52718) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:1(53), 1 packet
*Dec  1 10:07:51: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(625
Cisco1921#ena49) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:1(53), 1 packet
*Dec  1 10:07:51: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(55158) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:1(53), 1 packet
*Dec  1 10:07:51: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(50910) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:1(53), 1 packet
Cisco1921#ena_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(57859) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:1(53), 1 packet
*Dec  1 10:07:51: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(56658) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:1(53), 1 packet
*Dec  1 10:07:51: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(57465) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60:
Cisco1921#ena:53:1(53), 1 packet
*Dec  1 10:07:54: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(54299) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:2(53), 1 packet
*Dec  1 10:07:54: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(52718) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:2(53), 1 packet
Cisco1921#ena:909A:4044:64A9(62549) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:2(53), 1 packet
*Dec  1 10:07:54: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(55158) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:2(53), 1 packet
*Dec  1 10:07:54: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(50910) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:2(53), 1 packet
Cisco1921#enaCCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(57859) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:2(53), 1 packet
*Dec  1 10:07:54: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(56658) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:2(53), 1 packet
*Dec  1 10:07:54: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(64010) (GigabitEthernet0/1 a820.6652
Cisco1921#ena.4e84) -> 2001:A60::53:2(53), 1 packet
*Dec  1 10:07:54: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(58969) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:1(53), 1 packet
*Dec  1 10:07:54: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(63260) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:2(53), 1 packet
Cisco1921#ena:A61:3135:D500:DD3A:909A:4044:64A9(64617) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:1(53), 1 packet
*Dec  1 10:07:54: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(57465) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:2(53), 1 packet
*Dec  1 10:07:57: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied udp 2001:A61:3135:D500:DD3A:909A:4044:64A9(54898) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:A60::53:1(53), 1 packet
*Dec  1 10:0
Cisco1921#ena7:57: %IPV6_ACL-6-ACCESSLOGP: list WAN_OUTSIDE_INv6/100 denied tcp 2001:A61:3135:D500:DD3A:909A:4044:64A9(50287) (GigabitEthernet0/1 a820.6652.4e84) -> 2001:1BC0:AF::A1(80), 1 packet
macgyver1988
Am i also get a IPV6 address on the clients but i dont get ipv6 addresses for DNS , thats missing with DHCP..
