Flash:/ in read only moder Cisco C3560 48-TS-S
roadrunner992
like in the topic written, i cannot reset the switch, because of the read only mode of the flash:/
i havent found any solution that worked for me.
can anyone help me?
switch: dir
List of filesystems currently registered:
xmodem[0]: (read-only)
null[1]: (read-write)
bs[3]: (read-only)
flash[18]: (read-only)
tftp[19]: (read-write)
These commands a possible:
switch: ?
? -- Present list of available commands
arp -- Show arp table or arp-resolve an address
boot -- Load and boot an executable image
cat -- Concatenate (type) file(s)
copy -- Copy a file
delete -- Delete file(s)
dir -- List files in directories
emergency-install -- Initiate Disaster Recovery
flash_init -- Initialize filesystem(s)
format -- Format a filesystem
fsck -- Check filesystem consistency
help -- Present list of available commands
mgmt_init -- initialize management port
mkdir -- Create dir(s)
more -- Concatenate (display) file(s)
ping -- Send ICMP ECHO_REQUEST packets to a network host
readrtc -- Read RTC
rename -- Rename a file
reset -- Reset the system
rmdir -- Delete empty dir(s)
set -- Set or display environment variables
set_bs -- Set attributes on a boot sector filesystem
set_param -- Set system parameters in flash
type -- Concatenate (type) file(s)
unset -- Unset one or more environment variables
version -- Display boot loader version
writertc -- Write RTC
Thanks for your help
5 Replies 5
Giuseppe Larosa
Hello Philip,
somebody else had the same issue on same model of switch
see the following thread
https://community.cisco.com/t5/switching/changeing-flash-from-read-only-to-read-write/m-p/3739978
it is similar to password recovery procedure.
Hope to help
Giuseppe
Leo Laohoo
flash_init
load_helper
hey,
thats why i started this thread.
the problem is, that the commands in the other topic are not available
switch: load_helper
Unknown cmd: load_helper
switch: set BYPASS_STARTUP_CONFIG=1
Can't set variable with illegal char "=" (0x3d) in name.
I'm having the same issue. Did you find any solution for this?
I have already responded to your thread (LINK).
