Flash Keyword in 6500 boot system command
malcolmsalmons
I'm trying to determine the point of the flash keyword in the boot system command on a Sup-720. From what I can see I dont need to specify it but I would be interested to know if there is a good reason to specify it?
For example I can spectify:
boot system sup-bootdisk:IMAGENAME.bin
and everything works fine. However in the command reference it seems to indicate that I should put the following in:
boot system flash sup-bootdisk:IMAGENAME.bin
If anyone can clarify this then it would be appreciated.
Malcolm
Reza Sharifi
Usually, you specify the media in the statement, so you know which one you are booting from:
Here is an example:
boot system flash bootdisk:s2t54-advipservicesk9-mz.SPA.150-1.SY1.bin
Hi Reza
What I was actually after was whether I need to specify the keyword "flash" in the boot system command? I know the switch boots correctly when flash isnt included in the boot system command but was wondering if there were any reasons to include the flash keyword?
Malc
