Flexible Netflow 3750
Rawa Salah
Dears
please i have this cisco switch
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3750X-24       12.2(55)SE5           C3750E-UNIVERSALK9-M
i want to configure Flexible Netflow on this switch ,
guide me what is the configuration need to run flexible Netflow ?
realy i dont have information about Flexible Netflow ............ please help me
11 Replies 11
Lei Tian
First you need to make sure you have the 10G service module, which is required for netflow on 3750X. You can follow the following order to configure fleible netflow:
1, configure flow record (define your flow)
2, configure exporter (where to send the flow data)
3, combine flow record and exporter to a monitor
4, apply monitor to interface.
Also notes, for 3750X, the netflow can only be configured on service module port.
HTH,
Lei Tian
Dear Mr . Lei
Appreciated Your Answer,.......
please could you guide me for configuration of that steps ? really i dont have experience on Flexible Netflow....
Yas i have this 10G Module card , and this is my IOS emage
please is  this IOS image
c3750e-universalk9-mz.122-55.SE5.bin
is it need to upgrade ?
please help and Appreciated .........
Yes, you need 15.0(1)SE code to run netflow. So, upgrade is needed. See the following confogiration gudie
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/15.0_1_se/configuration/guide/swmnetflow.html
step1
flow record NETFLOW
match ipv4 source address
match ipv4 destination address
collect counter bytes
collect counter packets
step 2
flow monitor NETFLOW
destination 1.1.1.1
source loopback 0
step 3
record NETFLOW
exporter NETFLOW
step 4
interface G1/1/2
ip flow monitor NETFLOW input
HTH,
Lei Tian
Really you Are so helpfull ,
Thank you SO SO much
just telme more about ,all ( flow record , flowmonitor , record, exporter , ) must be the same name ( NETFLOW )   right ?
also why need loopback 0 ????   the destination (1.1.1.1) is Packet Analyzer user , right ????
can i set this netflow on LACP ports (2 port) ? i mean instead of ( interface gig 1/1/2 ) ?
APPRECIATED MR LEI
Hi Rawa,
You welcome! You dont have to use same name. I used same name in the example, but you can use different name, for example, test_record, test_monitor, test_exporter..
You dont have to use loopback0, but is recommended to source netflow from loopback interface.
Unfortunately, netflow is not supported on port-channel. The limitation is documented in the configuration guide.
HTH,
Lei Tian
Dear Lei
please this is Memory capacity of my switch
cisco WS-C3750X-24 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
you prefer to upgrade which ios image ? i mean c3750x universalk9 15 SE   or  c3750x ipservicesk9 15 SE ???
Hi Rawa,
It should be fine with either one. If you have smartnet contract, the proper way is to download universal image with ipservices license. Please refer the following license document for detail
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/white_paper_c11-579326_ps10745_Products_White_Paper.html
HTH,
Lei Tian
DEAR
PLEASE HELP ME AS SOON AS POSSIBLE
i upgraded the Switch , during botting i faced it and dont be complete
Switch uptime is 8 minutes, 15 seconds
Processor board ID FDO1701W1GR
01:35:45 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
-Traceback= 0xFFFFFF2Cz
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.2(1)E, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 27-Aug-13 11:06 by prod_rel_team
Program Exception (0x0700)!
SRR0 = 0x04002F60  SRR1 = 0x00029230  SRR2 = 0x02898534  SRR3 = 0x00029230
ESR = 0x08000000  DEAR = 0x00000000  TSR = 0x84000000  DBSR = 0x00000000
CPU Register Context:
Vector = 0x00000700  PC = 0x04002F60  MSR = 0x00029230  CR = 0x35000053
LR = 0x02005414  CTR = 0x00000000  XER = 0xE0000010
R0 = 0x00000000  R1 = 0x055D6E80  R2 = 0x00000000  R3 = 0x055D6EA0
R4 = 0x00000031  R5 = 0x055D6F54  R6 = 0x00000018  R7 = 0x0534A693
R8 = 0x0000001D  R9 = 0x0534A690  R10 = 0x00000017  R11 = 0x00000050
R12 = 0x00000000  R13 = 0x0B98279C  R14 = 0x00688E58  R15 = 0x00000002
R16 = 0x00000000  R17 = 0x0534A690  R18 = 0x00000001  R19 = 0x00000099
R20 = 0x04E2CDCD  R21 = 0x051D0000  R22 = 0x00000000  R23 = 0x00000002
R24 = 0x00000001  R25 = 0x055D6ED4  R26 = 0x04E2C9F8  R27 = 0x00000036
R28 = 0x00000004  R29 = 0x04E2C9D8  R30 = 0x05FEE5D8  R31 = 0x0000003A
Stack trace:
PC = 0x04002F60, SP = 0x055D6E80
Frame 00: SP = 0x055D6F98    PC = 0x020052CC
Frame 01: SP = 0x055D70C8    PC = 0x02006668
Frame 02: SP = 0x055D70E8    PC = 0x02006CCC
Frame 03: SP = 0x055D7198    PC = 0x02006FB4
Frame 04: SP = 0x055D71B8    PC = 0x028D881C
Frame 05: SP = 0x055D71F8    PC = 0x026BC780
Frame 06: SP = 0x055D7208    PC = 0x022AA47C
Frame 07: SP = 0x055D7228    PC = 0x022AA648
Frame 08: SP = 0x055D7240    PC = 0x022AA798
Frame 09: SP = 0x055D7270    PC = 0x00688C68
Frame 10: SP = 0x055D7378    PC = 0x00688EA0
Frame 11: SP = 0x055D7380    PC = 0x02D5771C
Frame 12: SP = 0x00000000    PC = 0x02D51C54
Switch uptime is 8 minutes, 18 seconds
01:35:48 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
Stack trace:
Hi Rawa,
Did some search on the traceback error, this seems to be a hardware related issue. Please open a case with TAC for further troubleshooting.
HTH,
Lei Tian
Please can i go to XMODEM to recover orignal IOS Image ? please give me urgent solution
Hi Rawa,
Did you delete the orginal image? Can you boot to ROMMON?
HTH,
Lei Tian
