Weird 30 second disconnects on 2960
markgirshovich
This is our setup:
LAN stations(VLAN 172)   ---------  2960-PoE ---------- Juniper SSG 140 FW (172.21.92.1)------------(ISP)
About 3 times a day all LAN stations loose connectivity (for 30 seconds) to default gateway (172.21.92.1) which is a trusted interface on Juniper FW.
If I do constant ping trace from LAN station I see that ping requests to Juniper do go away for 30 seconds. When we look at captures on the trunk port on the 2960, we actually see ICMP reply from Juniper getting to the switch, BUT they are not forwarded to end stations for some reason. Completely lost at what is causing this. Here is a link to capture from the switch trunk port:
https://docs.google.com/file/d/0B0HGSrwKgkvhbjJxYnFfWXgtaG8/edit?usp=sharing
Here is switch config:
2960Voice2#sh run
Building configuration...
Current configuration : 30357 bytes
! Last configuration change at 06:42:19 UTC Thu Sep 19 2013
! NVRAM config last updated at 06:42:21 UTC Thu Sep 19 2013
version 12.2
no service pad
service sequence-numbers
hostname 2960Voice2
boot-start-marker
boot-end-marker
enable secret 5 $1$30Ep$nFr7sPQEQeo.t.JcSEvzu.
no aaa new-model
system mtu routing 1500
ip subnet-zero
mls qos map policed-dscp  24 26 46 to 0
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2  1
mls qos srr-queue input cos-map queue 1 threshold 3  0
mls qos srr-queue input cos-map queue 2 threshold 1  2
mls qos srr-queue input cos-map queue 2 threshold 2  4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3  3 5
mls qos srr-queue input dscp-map queue 1 threshold 2  9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3  0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3  32
mls qos srr-queue input dscp-map queue 2 threshold 1  16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2  33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2  49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2  57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3  24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3  40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3  5
mls qos srr-queue output cos-map queue 2 threshold 3  3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3  2 4
mls qos srr-queue output cos-map queue 4 threshold 2  1
mls qos srr-queue output cos-map queue 4 threshold 3  0
mls qos srr-queue output dscp-map queue 1 threshold 3  40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3  24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3  48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3  56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3  16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3  32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1  8
mls qos srr-queue output dscp-map queue 4 threshold 2  9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3  0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
mls qos
crypto pki trustpoint HTTPS_SS_CERT_KEYPAIR
enrollment selfsigned
serial-number
revocation-check none
rsakeypair HTTPS_SS_CERT_KEYPAIR
crypto pki certificate chain HTTPS_SS_CERT_KEYPAIR
certificate self-signed 01
  30820267 308201D0 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  43311430 12060355 0403130B 32393630 566F6963 65322E31 2B300F06 03550405
  13083145 46333432 38303018 06092A86 4886F70D 01090216 0B323936 30566F69
  6365322E 301E170D 39333033 30313030 30363536 5A170D32 30303130 31303030
  3030305A 30433114 30120603 55040313 0B323936 30566F69 6365322E 312B300F
  06035504 05130831 45463334 32383030 1806092A 864886F7 0D010902 160B3239
  3630566F 69636532 2E30819F 300D0609 2A864886 F70D0101 01050003 818D0030
  81890281 8100BED1 4A936C70 1A6F724B D236D29E E94A18CA DF12514C 4D98E400
  F4842F51 C1AAE94A 01EB12AA 9815ABAC 33E55E18 C0709E6F F59216FE A934B3BE
  C9B99D30 0354F286 46374C80 5198F3ED D3613694 D71AA035 79E366A5 075FF394
  05E2C174 C54C4F2F CD86A624 E3C51646 F5CF055E 73126EE7 EB2B6EF8 1E784DEF
  E5B29561 791F0203 010001A3 6B306930 0F060355 1D130101 FF040530 030101FF
  30160603 551D1104 0F300D82 0B323936 30566F69 6365322E 301F0603 551D2304
  18301680 148DD85D DFDBFF88 296BC415 4B6B529E B59B8218 D3301D06 03551D0E
  04160414 8DD85DDF DBFF8829 6BC4154B 6B529EB5 9B8218D3 300D0609 2A864886
  F70D0101 04050003 8181003C 233610C5 7FE7FC86 2DB8821E 391F97B4 7C4FECE2
  FD8901C5 F272EA8B B4F6C7DF 186414D7 EB79F5DF 9A869303 07A13465 D3228A2B
  6770F993 CF2CABC5 60FEBE6A D2E12D94 C8D63B5F 9C9DAA7C DF580236 E2351496
  BB20507C 7C26BF4B 68DCE378 3C1C23A7 03FB2DF3 4AC3D111 D155E3E9 F06B744B
  7F84BCB5 958CCE55 69A4EA
  quit
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause channel-misconfig
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause sfp-config-mismatch
errdisable recovery cause gbic-invalid
errdisable recovery cause psecure-violation
errdisable recovery cause port-mode-failure
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause mac-limit
errdisable recovery cause vmps
errdisable recovery cause storm-control
errdisable recovery cause inline-power
errdisable recovery cause loopback
errdisable recovery cause small-frame
errdisable recovery interval 60
spanning-tree mode pvst
spanning-tree vlan 1-400 priority 24576
vlan internal allocation policy ascending
class-map match-all AutoQoS-VoIP-RTP-Trust
match ip dscp ef
class-map match-all AutoQoS-VoIP-Control-Trust
match ip dscp cs3  af31
policy-map AutoQoS-Police-CiscoPhone
class AutoQoS-VoIP-RTP-Trust
  set dscp ef
  police 1000000 8000 exceed-action policed-dscp-transmit
class AutoQoS-VoIP-Control-Trust
  set dscp cs3
interface FastEthernet0/1
switchport trunk native vlan 172
switchport mode trunk
speed 100
duplex full
srr-queue bandwidth share 10 10 60 20
priority-queue out
mls qos trust cos
macro description cisco-switch
auto qos voip trust
spanning-tree link-type point-to-point
interface FastEthernet0/2
switchport trunk native vlan 10
priority-queue out
mls qos trust cos
auto qos voip trust
interface FastEthernet0/3
priority-queue out
mls qos trust cos
auto qos voip trust
interface FastEthernet0/4
priority-queue out
mls qos trust cos
auto qos voip trust
interface FastEthernet0/5
priority-queue out
mls qos trust cos
auto qos voip trust
interface FastEthernet0/6
priority-queue out
mls qos trust cos
auto qos voip trust
interface FastEthernet0/7
switchport access vlan 172
switchport mode access
switchport voice vlan 10
switchport port-security maximum 5
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
macro description cisco-phone
auto qos voip cisco-phone
spanning-tree portfast
spanning-tree bpduguard enable
service-policy input AutoQoS-Police-CiscoPhone
interface FastEthernet0/8
priority-queue out
mls qos trust cos
interface FastEthernet0/9
priority-queue out
mls qos trust cos
interface FastEthernet0/10
priority-queue out
mls qos trust cos
interface FastEthernet0/11
speed 100
duplex full
priority-queue out
mls qos trust cos
interface FastEthernet0/12
priority-queue out
mls qos trust cos
interface FastEthernet0/13
priority-queue out
mls qos trust cos
interface FastEthernet0/14
priority-queue out
mls qos trust cos
interface FastEthernet0/15
priority-queue out
mls qos trust cos
interface FastEthernet0/16
priority-queue out
mls qos trust cos
interface FastEthernet0/17
priority-queue out
mls qos trust cos
interface FastEthernet0/18
priority-queue out
mls qos trust cos
interface FastEthernet0/19
priority-queue out
mls qos trust cos
interface FastEthernet0/20
priority-queue out
mls qos trust cos
interface FastEthernet0/21
priority-queue out
mls qos trust cos
interface FastEthernet0/22
priority-queue out
mls qos trust cos
interface FastEthernet0/23
priority-queue out
mls qos trust cos
interface FastEthernet0/24
priority-queue out
mls qos trust cos
interface FastEthernet0/25
priority-queue out
mls qos trust cos
interface FastEthernet0/26
priority-queue out
mls qos trust cos
interface FastEthernet0/27
priority-queue out
mls qos trust cos
interface FastEthernet0/28
priority-queue out
mls qos trust cos
interface FastEthernet0/29
priority-queue out
mls qos trust cos
interface FastEthernet0/30
priority-queue out
mls qos trust cos
interface FastEthernet0/31
priority-queue out
mls qos trust cos
interface FastEthernet0/32
priority-queue out
mls qos trust cos
interface FastEthernet0/33
priority-queue out
mls qos trust cos
interface FastEthernet0/34
priority-queue out
mls qos trust cos
interface FastEthernet0/35
priority-queue out
mls qos trust cos
interface FastEthernet0/36
priority-queue out
mls qos trust cos
interface FastEthernet0/37
switchport access vlan 192
macro description cisco-desktop
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
priority-queue out
mls qos trust cos
auto qos voip trust
interface FastEthernet0/48
switchport nonegotiate
priority-queue out
mls qos trust cos
macro description cisco-wireless
auto qos voip trust
interface GigabitEthernet0/1
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
interface GigabitEthernet0/2
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
interface GigabitEthernet0/3
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
interface GigabitEthernet0/4
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
interface Vlan1
no ip address
no ip route-cache
interface Vlan172
ip address 172.21.92.11 255.255.252.0
no ip route-cache
ip default-gateway 172.21.92.1
ip http server
ip http secure-server
control-plane
line con 0
line vty 0 4
password 2secure
login
length 0
line vty 5 15
password 2secure
login
length 0
monitor session 1 source interface Fa0/1
monitor session 1 destination interface Fa0/11
ntp clock-period 36028968
ntp server 64.4.10.33
end
2960Voice2#        sh vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/3, Fa0/4, Fa0/5, Fa0/6
                                                Fa0/47, Fa0/48, Gi0/1, Gi0/2
6    VLAN0006                         active
10   VLAN0010                         active    Fa0/7, Fa0/8, Fa0/9, Fa0/10
                                                Fa0/12, Fa0/13, Fa0/14, Fa0/15
                                                Fa0/16, Fa0/17, Fa0/18, Fa0/19
                                                Fa0/20, Fa0/21, Fa0/22, Fa0/23
                                                Fa0/24, Fa0/25, Fa0/26, Fa0/27
                                                Fa0/28, Fa0/29, Fa0/30, Fa0/31
                                                Fa0/32, Fa0/33, Fa0/34, Fa0/35
                                                Fa0/36
64   VLAN0064                         active
66   VLAN0066                         active
102  VLAN0102                         active
150  VLAN0150                         active
172  VLAN0172                         active    Fa0/7, Fa0/8, Fa0/9, Fa0/10
                                                Fa0/36
192  VLAN0192                         active    Fa0/37, Fa0/38, Fa0/39, Fa0/40
                                                Fa0/41, Fa0/42, Fa0/43, Fa0/44
                                                Fa0/45, Fa0/46
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
6    enet  100006     1500  -      -      -        -    -        0      0
10   enet  100010     1500  -      -      -        -    -        0      0
64   enet  100064     1500  -      -      -        -    -        0      0
66   enet  100066     1500  -      -      -        -    -        0      0
102  enet  100102     1500  -      -      -        -    -        0      0
150  enet  100150     1500  -      -      -        -    -        0      0
172  enet  100172     1500  -      -      -        -    -        0      0
192  enet  100192     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
2960Voice2#sh span
VLAN0001
  Spanning tree enabled protocol ieee
  Root ID    Priority    24577
             Address     3cdf.1ef3.4280
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    24577  (priority 24576 sys-id-ext 1)
             Aging Time 300
Interface           Role Sts Cost      Prio.Nbr Type
Fa0/1               Desg FWD 19        128.1    P2p
Fa0/2               Desg FWD 19        128.2    P2p
Gi0/3               Desg FWD 4         128.51   P2p
Gi0/4               Desg FWD 4         128.52   P2p
VLAN0006
  Root ID    Priority    24582
  Bridge ID  Priority    24582  (priority 24576 sys-id-ext 6)
             Aging Time 300
VLAN0010
  Root ID    Priority    24586
  Bridge ID  Priority    24586  (priority 24576 sys-id-ext 10)
             Aging Time 300
Fa0/7               Desg FWD 19        128.7    P2p Edge
Fa0/12              Desg FWD 19        128.12   P2p Edge
Fa0/13              Desg FWD 19        128.13   P2p Edge
Fa0/14              Desg FWD 19        128.14   P2p Edge
Fa0/15              Desg FWD 19        128.15   P2p Edge
Fa0/21              Desg FWD 19        128.21   P2p Edge
Fa0/22              Desg FWD 19        128.22   P2p Edge
Fa0/24              Desg FWD 19        128.24   P2p Edge
Fa0/25              Desg FWD 19        128.25   P2p Edge
Fa0/29              Desg FWD 19        128.29   P2p Edge
Fa0/30              Desg FWD 19        128.30   P2p Edge
Fa0/31              Desg FWD 19        128.31   P2p Edge
Fa0/32              Desg FWD 19        128.32   P2p Edge
Fa0/33              Desg FWD 19        128.33   P2p Edge
Fa0/36              Desg FWD 19        128.36   P2p Edge
VLAN0064
  Root ID    Priority    24640
  Bridge ID  Priority    24640  (priority 24576 sys-id-ext 64)
             Aging Time 300
VLAN0066
  Root ID    Priority    24642
  Bridge ID  Priority    24642  (priority 24576 sys-id-ext 66)
             Aging Time 300
VLAN0102
  Root ID    Priority    24678
  Bridge ID  Priority    24678  (priority 24576 sys-id-ext 102)
             Aging Time 300
VLAN0150
  Root ID    Priority    24726
  Bridge ID  Priority    24726  (priority 24576 sys-id-ext 150)
             Aging Time 300
VLAN0172
  Root ID    Priority    24748
  Bridge ID  Priority    24748  (priority 24576 sys-id-ext 172)
             Aging Time 300
VLAN0192
  Root ID    Priority    24768
  Bridge ID  Priority    24768  (priority 24576 sys-id-ext 192)
             Aging Time 300
2960Voice2# sh int coun
Port            InOctets    InUcastPkts    InMcastPkts    InBcastPkts
Fa0/1         1960937714        2646447            509          17773
Fa0/2           20926686         271332              0           2469
Fa0/3                  0              0              0              0
Fa0/4                  0              0              0              0
Fa0/5                  0              0              0              0
Fa0/6                  0              0              0              0
Fa0/7           66889417         190014         105215         117300
Fa0/8                  0              0              0              0
Fa0/9                  0              0              0              0
Fa0/10                 0              0              0              0
Fa0/11                 0              0              0              0
Fa0/12          39348643         191210          13424           1314
Fa0/13           7667084          23587           9250            858
Fa0/14          78166674         330467          15089          73846
Fa0/15           1716100           3431           6372              9
Fa0/16                 0              0              0              0
Fa0/17                 0              0              0              0
Fa0/18                 0              0              0              0
Fa0/19           3272416          12607           1227            478
Fa0/20          27634622         277678           1578           1273
Fa0/21           1418394          11231           3186              0
Fa0/22           7648148          75469           6372              7
Fa0/23                 0              0              0              0
Fa0/24         276299037         650029          16439           8973
Fa0/25           3437904           6863          12744             22
Fa0/26                 0              0              0              0
Fa0/27                 0              0              0              0
Fa0/28                 0              0              0              0
Fa0/29           2234430           5520           6588             94
Fa0/30          88652193         392185         146415          89815
Fa0/31           3191965          12743           6507             56
Fa0/32           5034238          30832           6592             61
Fa0/33          17169742          87068             32           3627
Fa0/34                 0              0              0              0
Fa0/35                 0              0              0              0
Fa0/36                 0              0              0              0
Fa0/37                 0              0              0              0
Fa0/38                 0              0              0              0
Fa0/39                 0              0              0              0
Fa0/40                 0              0              0              0
Fa0/41                 0              0              0              0
Fa0/42                 0              0              0              0
Fa0/43                 0              0              0              0
Fa0/44                 0              0              0              0
Fa0/45                 0              0              0              0
Fa0/46                 0              0              0              0
Fa0/47                 0              0              0              0
Fa0/48         113352944         121264           5400            111
Gi0/1                  0              0              0              0
Gi0/2                  0              0              0              0
Gi0/3          130914102         355528           3813           2167
Gi0/4          162529404         594315           3655           1705
Port           OutOctets   OutUcastPkts   OutMcastPkts   OutBcastPkts
Fa0/1          964254837        2644311        1230978         304824
Fa0/2          183863530         302608        1231487         320295
Fa0/3                  0              0              0              0
Fa0/4                  0              0              0              0
Fa0/5                  0              0              0              0
Fa0/6                  0              0              0              0
Fa0/7          116520491         185027         363671         204847
Fa0/8                  0              0              0              0
Fa0/9                  0              0              0              0
Fa0/10                 0              0              0              0
Fa0/11                 0              0              0              0
Fa0/12         263060539         242839         461801         320837
Fa0/13         121735204          44109         459584         321292
Fa0/14         260343801         330844         450779         248311
Fa0/15         105626722          22593         462464         322143
Fa0/16                 0              0              0              0
Fa0/17                 0              0              0              0
Fa0/18                 0              0              0              0
Fa0/19          25652370          16458          58962          53992
Fa0/20         606228515         434980          10888           9548
Fa0/21         105643416          23047         462465         321829
Fa0/22         111539230          94673         462465         322145
Fa0/23                 0              0              0              0
Fa0/24         786261745         782260         458790         313179
Fa0/25         105855190          25807         462465         322130
Fa0/26                 0              0              0              0
Fa0/27                 0              0              0              0
Fa0/28            383822             82           1595           1459
Fa0/29         106405101          24636         462267         322059
Fa0/30         217961734         280601         322494         232337
Fa0/31         107772796          31810         462334         322096
Fa0/32         108593940          50032         462273         322094
Fa0/33         122424458         105542         462433         318526
Fa0/34                 0              0              0              0
Fa0/35                 0              0              0              0
Fa0/36         105397420          19377         462465         322152
Fa0/37                 0              0              0              0
Fa0/38                 0              0              0              0
Fa0/39                 0              0              0              0
Fa0/40                 0              0              0              0
Fa0/41                 0              0              0              0
Fa0/42                 0              0              0              0
Fa0/43                 0              0              0              0
Fa0/44                 0              0              0              0
Fa0/45                 0              0              0              0
Fa0/46                 0              0              0              0
Fa0/47                 0              0              0              0
Fa0/48          96791912         101902         158323          58077
Gi0/1                  0              0              0              0
Gi0/2                  0              0              0              0
Gi0/3          222235415         341190        1227703         320601
Gi0/4          259552618         573741        1227861         321063
2960Voice2# sh int summ
*: interface is up
IHQ: pkts in input hold queue     IQD: pkts dropped from input queue
OHQ: pkts in output hold queue    OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec)          RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec)          TXPS: tx rate (pkts/sec)
TRTL: throttle count
  Interface               IHQ   IQD  OHQ   OQD  RXBS RXPS  TXBS TXPS TRTL
* Vlan1                    0     0    0     0     0    0     0    0    0
* Vlan172                  0     0    0     0     0    1     0    0    0
* FastEthernet0/1          0     0    0    78  7000    8 33000   18    0
* FastEthernet0/2          0     0    0     0     0    0  4000    8    0
  FastEthernet0/3          0     0    0     0     0    0     0    0    0
  FastEthernet0/4          0     0    0     0     0    0     0    0    0
  FastEthernet0/5          0     0    0     0     0    0     0    0    0
  FastEthernet0/6          0     0    0     0     0    0     0    0    0
* FastEthernet0/7          0     0    0     0     0    0  1000    2    0
  FastEthernet0/8          0     0    0     0     0    0     0    0    0
  FastEthernet0/9          0     0    0     0     0    0     0    0    0
  FastEthernet0/10         0     0    0     0     0    0     0    0    0
  FastEthernet0/11         0     0    0     0     0    0     0    0    0
* FastEthernet0/12         0     0    0     0     0    0  2000    3    0
* FastEthernet0/13         0     0    0     0     0    0  2000    3    0
* FastEthernet0/14         0     0    0     0     0    0  2000    3    0
* FastEthernet0/15         0     0    0     0     0    0  2000    3    0
  FastEthernet0/16         0     0    0     0     0    0     0    0    0
  FastEthernet0/17         0     0    0     0     0    0     0    0    0
  FastEthernet0/18         0     0    0     0     0    0     0    0    0
  FastEthernet0/19         0     0    0     0     0    0     0    0    0
  FastEthernet0/20         0     0    0     0     0    0     0    0    0
* FastEthernet0/21         0     0    0     0     0    0  2000    4    0
* FastEthernet0/22         0     0    0     0     0    0  2000    4    0
  FastEthernet0/23         0     0    0     0     0    0     0    0    0
* FastEthernet0/24         0     0    0     0     0    0  2000    4    0
* FastEthernet0/25         0     0    0     0     0    0  2000    4    0
  FastEthernet0/26         0     0    0     0     0    0     0    0    0
  FastEthernet0/27         0     0    0     0     0    0     0    0    0
  FastEthernet0/28         0     0    0     0     0    0     0    0    0
* FastEthernet0/29         0     0    0     0     0    0  2000    3    0
* FastEthernet0/30         0     0    0     0  3000    2 10000    4    0
* FastEthernet0/31         0     0    0     0     0    0  2000    3    0
* FastEthernet0/32         0     0    0     0     0    0  2000    3    0
* FastEthernet0/33         0     0    0     0  1000    0  2000    3    0
  FastEthernet0/34         0     0    0     0     0    0     0    0    0
  FastEthernet0/35         0     0    0     0     0    0     0    0    0
* FastEthernet0/36         0     0    0     0     0    0  2000    3    0
  FastEthernet0/37         0     0    0     0     0    0     0    0    0
  FastEthernet0/38         0     0    0     0     0    0     0    0    0
  FastEthernet0/39         0     0    0     0     0    0     0    0    0
  FastEthernet0/40         0     0    0     0     0    0     0    0    0
  FastEthernet0/41         0     0    0     0     0    0     0    0    0
  FastEthernet0/42         0     0    0     0     0    0     0    0    0
  FastEthernet0/43         0     0    0     0     0    0     0    0    0
  FastEthernet0/44         0     0    0     0     0    0     0    0    0
  FastEthernet0/45         0     0    0     0     0    0     0    0    0
  FastEthernet0/46         0     0    0     0     0    0     0    0    0
  FastEthernet0/47         0     0    0     0     0    0     0    0    0
  FastEthernet0/48         0     0    0     0     0    0     0    0    0
  GigabitEthernet0/1       0     0    0     0     0    0     0    0    0
  GigabitEthernet0/2       0     0    0     0     0    0     0    0    0
* GigabitEthernet0/3       0     0    0     0  1000    2  8000   10    0
* GigabitEthernet0/4       0     0    0     0 20000    9 12000   15    0
Vlan1
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
Vlan172
               Processor     364093   24269336      25393   19262084
             Route cache          0          0          0          0
                   Total     364093   24269336      25393   19262084
FastEthernet0/1
               Processor          0          0     981002   67952108
             Route cache          0          0          0          0
                   Total          0          0     981002   67952108
FastEthernet0/2
             Route cache          0          0          0          0
FastEthernet0/3
               Processor          0          0          0          0
   Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/4
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/5
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/6
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/7
               Processor          0          0     212760   16140374
             Route cache          0          0          0          0
                   Total          0          0     212760   16140374
FastEthernet0/8
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/9
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/10
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/11
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/12
               Processor          0          0     212761   16143628
             Route cache          0          0          0          0
Total          0          0     212761   16143628
FastEthernet0/13
               Processor          0          0     212762   16143696
             Route cache          0          0          0          0
                   Total          0          0     212762   16143696
FastEthernet0/14
             Route cache          0          0          0          0
FastEthernet0/15
             Route cache          0          0          0          0
FastEthernet0/16
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/17
Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/18
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/19
               Processor          0          0      27226    2072042
             Route cache          0          0          0          0
                   Total          0          0      27226    2072042
FastEthernet0/20
               Processor          0          0       4842     371516
             Route cache          0          0          0          0
                   Total          0          0       4842     371516
FastEthernet0/21
               Processor          0          0     212763   16144314
             Route cache          0          0          0          0
                   Total          0          0     212763   16144314
FastEthernet0/22
             Route cache          0          0          0          0
FastEthernet0/23
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/24
             Route cache          0          0          0          0
FastEthernet0/25
             Route cache          0          0          0          0
FastEthernet0/26
               Processor          0          0          0          0
Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/27
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/28
               Processor          0          0        756      59940
             Route cache          0          0          0          0
                   Total          0          0        756      59940
FastEthernet0/29
             Route cache          0          0          0          0
FastEthernet0/30
             Route cache          0          0          0          0
FastEthernet0/31
             Route cache          0          0          0          0
FastEthernet0/32
             Route cache          0          0          0          0
FastEthernet0/33
             Route cache          0          0          0          0
FastEthernet0/34
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/35
               Processor          0          0          0          0
             Route cache          0          0          0          0
  Total          0          0          0          0
FastEthernet0/36
             Route cache          0          0          0          0
FastEthernet0/37
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/38
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/39
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/40
   Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/41
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/42
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/43
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/44
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/45
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/46
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/47
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
FastEthernet0/48
               Processor          0          0     118561   10445428
             Route cache          0          0          0          0
                   Total          0          0     118561   10445428
GigabitEthernet0/1
               Processor          0          0          0          0
  Route cache          0          0          0          0
                   Total          0          0          0          0
GigabitEthernet0/2
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
GigabitEthernet0/3
               Processor          0          0     981022   67963018
             Route cache          0          0          0          0
                   Total          0          0     981022   67963018
GigabitEthernet0/4
             Route cache          0          0          0          0
2960Voice2#    sh int stat
Vlan1 is up, line protocol is up
  Hardware is EtherSVI, address is 3cdf.1ef3.42c0 (bia 3cdf.1ef3.42c0)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not supported
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 2d05h
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 interface resets
Vlan172 is up, line protocol is up
  Hardware is EtherSVI, address is 3cdf.1ef3.42c1 (bia 3cdf.1ef3.42c1)
Internet address is 172.21.92.11/22
  Last input 00:00:00, output 00:00:01, output hang never
  5 minute input rate 3000 bits/sec, 5 packets/sec
  5 minute output rate 5000 bits/sec, 2 packets/sec
     364173 packets input, 24274304 bytes, 0 no buffer
     25441 packets output, 19283082 bytes, 0 underruns
FastEthernet0/1 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.4281 (bia 3cdf.1ef3.4281)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 78
  5 minute input rate 22000 bits/sec, 12 packets/sec
  5 minute output rate 39000 bits/sec, 21 packets/sec
     2665899 packets input, 1961598306 bytes, 0 no buffer
     Received 18300 broadcasts (509 multicasts)
     7 input errors, 5 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 509 multicast, 0 pause input
     4181624 packets output, 964700985 bytes, 0 underruns
FastEthernet0/2 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.4282 (bia 3cdf.1ef3.4282)
  5 minute output rate 4000 bits/sec, 7 packets/sec
     273807 packets input, 20927088 bytes, 0 no buffer
     Received 2469 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
   1854763 packets output, 183898192 bytes, 0 underruns
FastEthernet0/3 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.4283 (bia 3cdf.1ef3.4283)
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Auto-duplex, Auto-speed, media type is 10/100BaseTX
     Received 0 broadcasts (0 multicasts)
FastEthernet0/4 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.4284 (bia 3cdf.1ef3.4284)
FastEthernet0/5 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.4285 (bia 3cdf.1ef3.4285)
FastEthernet0/6 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.4286 (bia 3cdf.1ef3.4286)
FastEthernet0/7 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.4287 (bia 3cdf.1ef3.4287)
  Last input 00:00:17, output 00:00:00, output hang never
  5 minute input rate 2000 bits/sec, 2 packets/sec
  5 minute output rate 2000 bits/sec, 3 packets/sec
     412722 packets input, 66935332 bytes, 0 no buffer
     Received 222595 broadcasts (105268 multicasts)
     0 watchdog, 105268 multicast, 0 pause input
     753768 packets output, 116560363 bytes, 0 underruns
FastEthernet0/8 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.4288 (bia 3cdf.1ef3.4288)
FastEthernet0/9 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.4289 (bia 3cdf.1ef3.4289)
FastEthernet0/10 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.428a (bia 3cdf.1ef3.428a)
FastEthernet0/11 is down, line protocol is down (monitoring)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.428b (bia 3cdf.1ef3.428b)
FastEthernet0/12 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.428c (bia 3cdf.1ef3.428c)
  Last input 00:00:07, output 00:00:00, output hang never
     205952 packets input, 39349572 bytes, 0 no buffer
     Received 14742 broadcasts (13428 multicasts)
     0 watchdog, 13428 multicast, 0 pause input
     1025664 packets output, 263084780 bytes, 0 underruns
FastEthernet0/13 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 3cdf.1ef3.428d (bia 3cdf.1ef3.428d)
  Last input 00:00:40, output 00:00:00, output hang never
     33697 packets input, 7667543 bytes, 0 no buffer
     Received 10110 broadcasts (9252 multicasts)
     0 watchdog, 9252 multicast, 0 pause input
     825172 packets output, 121759445 bytes, 0 underruns
FastEthernet0/14 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.428e (bia 3cdf.1ef3.428e)
  Last input 00:00:08, output 00:00:01, output hang never
     419405 packets input, 78166973 bytes, 0 no buffer
     Received 88936 broadcasts (15090 multicasts)
    0 watchdog, 15090 multicast, 0 pause input
     1030121 packets output, 260368030 bytes, 0 underruns
FastEthernet0/15 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.428f (bia 3cdf.1ef3.428f)
  Last input 00:00:30, output 00:00:01, output hang never
   9814 packets input, 1716558 bytes, 0 no buffer
     Received 6383 broadcasts (6374 multicasts)
     0 watchdog, 6374 multicast, 0 pause input
     807385 packets output, 105650809 bytes, 0 underruns
FastEthernet0/16 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.4290 (bia 3cdf.1ef3.4290)
FastEthernet0/17 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.4291 (bia 3cdf.1ef3.4291)
FastEthernet0/18 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.4292 (bia 3cdf.1ef3.4292)
astEthernet0/19 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.4293 (bia 3cdf.1ef3.4293)
  Last input 1d22h, output 1d15h, output hang never
     14312 packets input, 3272416 bytes, 0 no buffer
     Received 1705 broadcasts (1227 multicasts)
     0 watchdog, 1227 multicast, 0 pause input
     129412 packets output, 25652370 bytes, 0 underruns
FastEthernet0/20 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.4294 (bia 3cdf.1ef3.4294)
  Last input 1d23h, output 1d21h, output hang never
     280529 packets input, 27634622 bytes, 0 no buffer
     Received 2851 broadcasts (1578 multicasts)
     0 watchdog, 1578 multicast, 0 pause input
     455416 packets output, 606228515 bytes, 0 underruns
FastEthernet0/21 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.4295 (bia 3cdf.1ef3.4295)
  Last input 00:00:58, output 00:00:00, output hang never
5 minute output rate 3000 bits/sec, 2 packets/sec
     14421 packets input, 1418757 bytes, 0 no buffer
     Received 3186 broadcasts (3186 multicasts)
     0 watchdog, 3186 multicast, 0 pause input
     807532 packets output, 105668028 bytes, 0 underruns
FastEthernet0/22 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.4296 (bia 3cdf.1ef3.4296)
  Last input 00:00:11, output 00:00:00, output hang never
     81852 packets input, 7648760 bytes, 0 no buffer
     Received 6381 broadcasts (6374 multicasts)
     879474 packets output, 111563842 bytes, 0 underruns
FastEthernet0/23 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.4297 (bia 3cdf.1ef3.4297)
FastEthernet0/24 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.4298 (bia 3cdf.1ef3.4298)
  Last input 00:00:15, output 00:00:00, output hang never
     675445 packets input, 276299956 bytes, 0 no buffer
     Received 25416 broadcasts (16443 multicasts)
     0 watchdog, 16443 multicast, 0 pause input
     1554419 packets output, 786286279 bytes, 0 underruns
FastEthernet0/25 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.4299 (bia 3cdf.1ef3.4299)
  Last input 00:00:19, output 00:00:00, output hang never
  5 minute output rate 3000 bits/sec, 3 packets/sec
     19637 packets input, 3439114 bytes, 0 no buffer
     Received 12770 broadcasts (12748 multicasts)
     0 watchdog, 12748 multicast, 0 pause input
   810596 packets output, 105880008 bytes, 0 underruns
FastEthernet0/26 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.429a (bia 3cdf.1ef3.429a)
FastEthernet0/27 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.429b (bia 3cdf.1ef3.429b)
FastEthernet0/28 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.429c (bia 3cdf.1ef3.429c)
  Last input 3d05h, output 1d22h, output hang never
     3136 packets output, 383822 bytes, 0 underruns
FastEthernet0/29 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.429d (bia 3cdf.1ef3.429d)
  Last input 00:00:43, output 00:00:01, output hang never
     12204 packets input, 2234889 bytes, 0 no buffer
     Received 6684 broadcasts (6590 multicasts)
     0 watchdog, 6590 multicast, 0 pause input
     809157 packets output, 106429967 bytes, 0 underruns
FastEthernet0/30 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.429e (bia 3cdf.1ef3.429e)
  Last input 00:00:49, output 00:00:01, output hang never
  5 minute input rate 5000 bits/sec, 3 packets/sec
  5 minute output rate 13000 bits/sec, 3 packets/sec
     629052 packets input, 88763756 bytes, 0 no buffer
     Received 236294 broadcasts (146452 multicasts)
     0 watchdog, 146452 multicast, 0 pause input
     836189 packets output, 218562677 bytes, 0 underruns
FastEthernet0/31 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.429f (bia 3cdf.1ef3.429f)
  Last input 00:00:37, output 00:00:01, output hang never
     19307 packets input, 3192112 bytes, 0 no buffer
     Received 6564 broadcasts (6508 multicasts)
     0 watchdog, 6508 multicast, 0 pause input
     816439 packets output, 107798033 bytes, 0 underruns
FastEthernet0/32 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.42a0 (bia 3cdf.1ef3.42a0)
     37487 packets input, 5034697 bytes, 0 no buffer
   Received 6655 broadcasts (6594 multicasts)
     0 watchdog, 6594 multicast, 0 pause input
     834598 packets output, 108619177 bytes, 0 underruns
FastEthernet0/33 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.42a1 (bia 3cdf.1ef3.42a1)
  5 minute output rate 4000 bits/sec, 4 packets/sec
     90784 packets input, 17181719 bytes, 0 no buffer
     Received 3659 broadcasts (32 multicasts)
     0 watchdog, 32 multicast, 0 pause input
     886756 packets output, 122460608 bytes, 0 underruns
FastEthernet0/34 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.42a2 (bia 3cdf.1ef3.42a2)
FastEthernet0/35 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.42a3 (bia 3cdf.1ef3.42a3)
FastEthernet0/36 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.42a4 (bia 3cdf.1ef3.42a4)
     804200 packets output, 105423187 bytes, 0 underruns
FastEthernet0/37 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.42a5 (bia 3cdf.1ef3.42a5)
FastEthernet0/38 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.42a6 (bia 3cdf.1ef3.42a6)
FastEthernet0/39 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.42a7 (bia 3cdf.1ef3.42a7)
FastEthernet0/40 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.42a8 (bia 3cdf.1ef3.42a8)
FastEthernet0/41 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.42a9 (bia 3cdf.1ef3.42a9)
FastEthernet0/42 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.42aa (bia 3cdf.1ef3.42aa)
FastEthernet0/43 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.42ab (bia 3cdf.1ef3.42ab)
FastEthernet0/44 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.42ac (bia 3cdf.1ef3.42ac)
FastEthernet0/45 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.42ad (bia 3cdf.1ef3.42ad)
FastEthernet0/46 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.42ae (bia 3cdf.1ef3.42ae)
FastEthernet0/47 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.42af (bia 3cdf.1ef3.42af)
FastEthernet0/48 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 3cdf.1ef3.42b0 (bia 3cdf.1ef3.42b0)
  Last input 1d22h, output 1d22h, output hang never
     126775 packets input, 113352944 bytes, 0 no buffer
     Received 5511 broadcasts (5400 multicasts)
     0 watchdog, 5400 multicast, 0 pause input
     318302 packets output, 96791912 bytes, 0 underruns
GigabitEthernet0/1 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 3cdf.1ef3.42b1 (bia 3cdf.1ef3.42b1)
  Keepalive not set
  Auto-duplex, Auto-speed, link type is auto, media type is Not Present
GigabitEthernet0/2 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 3cdf.1ef3.42b2 (bia 3cdf.1ef3.42b2)
  Keepalive not set
GigabitEthernet0/3 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 3cdf.1ef3.42b3 (bia 3cdf.1ef3.42b3)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  5 minute output rate 7000 bits/sec, 9 packets/sec
     361632 packets input, 130952202 bytes, 0 no buffer
     Received 5982 broadcasts (3814 multicasts)
     0 watchdog, 3814 multicast, 0 pause input
     1890032 packets output, 222287787 bytes, 0 underruns
GigabitEthernet0/4 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 3cdf.1ef3.42b4 (bia 3cdf.1ef3.42b4)
  5 minute input rate 39000 bits/sec, 15 packets/sec
  5 minute output rate 18000 bits/sec, 20 packets/sec
     601180 packets input, 163357740 bytes, 0 no buffer
     Received 5362 broadcasts (3656 multicasts)
     0 watchdog, 3656 multicast, 0 pause input
     2124111 packets output, 259773406 bytes, 0 underruns
2960Voice2#   sh ver
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(46)SE, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 21-Aug-08 15:59 by nachen
Image text-base: 0x00003000, data-base: 0x01200000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(46r)SE2, RELEASE SOFTWARE (fc1)
2960Voice2 uptime is 1 week, 6 days, 24 minutes
System restarted at 01:23:21 UTC Tue Sep 10 2013
System image file is "flash:/c2960-lanbasek9-mz.122-46.SE/c2960-lanbasek9-mz.122-46.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960-48PST-L (PowerPC405) processor (revision B0) with 61440K/4088K bytes of memory.
Processor board ID FOC1344Z3H5
Last reset from power-on
2 Virtual Ethernet interfaces
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 3C:DF:1E:F3:42:80
Motherboard assembly number     : 73-11882-06
Power supply part number        : 341-0266-02
Motherboard serial number       : FOC13443QF1
Power supply serial number      : DCA1342H1GU
Model revision number           : B0
Motherboard revision number     : A0
Model number                    : WS-C2960-48PST-L
System serial number            : FOC1344Z3H5
Top Assembly Part Number        : 800-30874-01
Top Assembly Revision Number    : E0
Version ID                      : V01
CLEI Code Number                : COMWH10CRA
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C2960-48PST-L   12.2(46)SE            C2960-LANBASEK9-M
Configuration register is 0xF
2960Voice2#sh cdp
Global CDP information:
Sending CDP packets every 60 seconds
Sending a holdtime value of 180 seconds
Sending CDPv2 advertisements is enabled
2960Voice2#sh cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
SEP0004f2f568b4  Fas 0/21          140           H P      IP Phone  port 1
SEP006440B51499  Fas 0/22          127           H P      IP Phone  Port 1
SEPF02929E2D441  Fas 0/13          156           H P      IP Phone  Port 1
SEPB4E9B08DA132  Fas 0/32          161           H P      IP Phone  Port 1
SEPD0574C6A46BF  Fas 0/30          151           H P      IP Phone  Port 1
SEPB4E9B08DA150  Fas 0/12          130           H P      IP Phone  Port 1
SEPB4E9B08CC708  Fas 0/31          164           H P      IP Phone  Port 1
SEPE840400CB247  Fas 0/25          174           H P      IP Phone  Port 1
SEPE840400CB1DB  Fas 0/15          167           H P      IP Phone  Port 1
SEP64AE0C5FCBFC  Fas 0/25          121           H P      IP Phone  Port 1
SEP1CAA0710B986  Fas 0/24          154           H P      IP Phone  Port 1
SEPB4E9B08D9FA4  Fas 0/12          164           H P      IP Phone  Port 1
SEPB4E9B08CC5A9  Fas 0/29          158           H P      IP Phone  Port 1
SEPB4E9B08D9AA5  Fas 0/24          124           H P      IP Phone  Port 1
SEPB4E9B08CE7A8  Fas 0/14          129           H P      IP Phone  Port 1
SEP1CAA0710B871  Fas 0/7           179           H P      IP Phone  Port 1
2960Voice2# exit
Richard Burts
The mention that the issue lasts 30 seconds makes me wonder if there is some spanning tree issue here. Could you enable any logging available for spanning tree and then check the syslogs for any sign of spanning tree activity at the time when the issue happens?
Rick
Rick
My first thought were the same as Rick's - 30 seconds would be the time it takes a non-portfast interface to move from initialization through forwarding.
I see you have errdibale recovery on across the board - nspot a good practice; although errors there would take 300 seconds to recover by default.
