Flexible NetFlow - Empty Cache
amm.jwalker
Visitor
I've been experiencing problems with flexible netflow on a 2811 running 15.1(3)T4. The cache seems to fill up quickly (in a matter of hours?) and then gets completely stuck. I'm not sure if this might be a problem with my config or an IOS caveat. It does seem to be related to DMVPN though.
2811 with DMVPN:
amm-isr1#sh flow monitor STANDARD_MONITOR cache
  Cache type:                               Normal
  Cache size:                                 8192
  Current entries:                      4294967294
  High Watermark:                       4294967295
  Flows added:                              360359
  Flows not added:                          244614
  Flows aged:                               352167
    - Active timeout      (    60 secs)       3951
    - Inactive timeout    (    15 secs)     330556
    - Event aged                                 0
    - Watermark aged                         17660
    - Emergency aged                             0
There are no cache entries to display.
Flow Monitor STANDARD_MONITOR:
  Description:       User defined
  Flow Record:       STANDARD_RECORD
  Flow Exporter:     SCRUTINIZER
  Cache:
    Type:              normal
    Status:            allocated
    Size:              8192 entries / 917560 bytes
    Inactive Timeout:  15 secs
    Active Timeout:    60 secs
    Update Timeout:    1800 secs
amm-isr1#sh flow monitor STANDARD_MONITOR stat
  Cache type:                               Normal
  Cache size:                                 8192
  Flows added:                              360359
  Flows aged:                               352167
    - Event aged                                 0
    - Emergency aged                             0
Netflow config:
amm-isr1#sh run | begin flow record
flow record STANDARD_RECORD
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
match flow direction
match application name
collect datalink mac source address input
collect datalink mac destination address input
collect routing destination as
collect routing next-hop address ipv4
collect ipv4 dscp
collect ipv4 id
collect ipv4 source prefix
collect ipv4 source mask
collect ipv4 destination prefix
collect ipv4 destination mask
collect transport tcp source-port
collect transport tcp destination-port
collect transport tcp flags
collect transport udp source-port
collect transport udp destination-port
collect interface output
collect flow sampler
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow exporter SCRUTINIZER
destination 10.2.40.25
source Loopback0
transport udp 2055
template data timeout 60
option interface-table
option exporter-stats
option application-table
cache timeout active 60
cache entries 8192
DMVPN interface config:
amm-isr1#sh run | begin interface Tunnel0
interface Tunnel0
description DMVPN SPOKE
bandwidth 10000
ip address 172.16.1.2 255.255.255.0
no ip redirects
ip mtu 1400
ip flow monitor STANDARD_MONITOR input
ip flow monitor STANDARD_MONITOR output
ip pim nbma-mode
ip pim sparse-dense-mode
ip nhrp authentication ******
ip nhrp group DMVPN_GROUP_MT
ip nhrp map multicast dynamic
ip nhrp map multicast ******
ip nhrp map 172.16.1.1 ******
ip nhrp network-id 1
ip nhrp nhs 172.16.1.1
ip tcp adjust-mss 1360
load-interval 30
delay 2000
qos pre-classify
tunnel source FastEthernet0/0.1
tunnel mode gre multipoint
tunnel key 0
tunnel protection ipsec profile VTI_PROF
Note, I'm running the exact same netflow configuration on 1 2821 with 15.1(3)T4 and 2 2911s with 15.2(4)M2. Interestingly enough, the watermark value on routers with DMVPN is maxed while normal otherwise:
2821 (with DMVPN):
dfh-isr1#sh flow monitor STANDARD_MONITOR statistics
  Cache type:                               Normal
  Cache size:                                 4096
  Current entries:                             567
  Flows added:                            73883592
  Flows aged:                             73882837
    - Active timeout      (    60 secs)    6175577
    - Inactive timeout    (    15 secs)   67707260
    - Event aged                                 0
    - Watermark aged                             0
    - Emergency aged                             0
2911 (with DMVPN):
  Cache type:                               Normal
  Cache size:                                 4096
  Current entries:                            1100
  Flows added:                           139226115
  Flows not added:                            1696
  Flows aged:                            139224969
    - Active timeout      (    60 secs)   11894919
    - Inactive timeout    (    15 secs)  127240921
    - Event aged                                 0
    - Watermark aged                         67659
    - Emergency aged                         21470
2911 (without DMVPN):
dfh-isr2#sh flow monitor STANDARD_MONITOR statistics
  Cache type:                               Normal
  Cache size:                                 4096
  Current entries:                             520
  High Watermark:                             3961
  Flows added:                           111800119
  Flows aged:                            111799569
    - Active timeout      (    60 secs)   11270227
    - Inactive timeout    (    15 secs)  100529225
    - Event aged                                 0
    - Watermark aged                           117
    - Emergency aged                             0
To me, this certainly looks like a DMVPN related issue, but I'm not sure what the fix is. There's an open caveat on 15.1, CSCud86954, but that involves conditions that don't apply to my config (PBR matching IPSEC traffic). Any ideas?
0 Replies 0
