Bookmark
Subscribe
703
Flexible Netflow for ASR 1001
I have an ASR 1001 router.  I have enabled flexible netflow with the following commands below
flow record AAAA
match interface input
match interface output
flow exporter BBBBB
destination 10.10.89.71 vrf Mgmt-Intf   ---->this is the Ip address of my Orion neflow server
source GigabitEthernet0
transport udp 2055 ---> My netflow server listens on 2055.  by default this was 90
flow monitor FFFFF
record AAAA
exporter BBBBB
INTERFACE G0/0/2
ip flow monitor FFFFF
One thing that I found interestesting was enable cef on the router was not the nortmal ip cef in global configuration mode.
The command i used was ip cef account non-recursive.
Any suggestions.
When I use the ip flow export my counters are set to 0
0 Replies 0
