need help in setup vpn with IGMP enabled !
Dr.X
Level 2
Level 2
hi all
i hve cisco 2901 router and i want to setup vpn that allow IGMP ,
can somebody help me with it or at least sample configuration ?
can it be done from http gui ? or it is mandatory from cli ?
regards
Julio Carvajal
So you plan to send multicast traffic over the tunnel?
It could be possible to do it via both ways, thing is is harder to get assistance via GUI as for example I have no access to any router. I reply based on commands that I remember so CLI is a must.
I would recommend using a GRE tunnel to send the Multicast traffic through it
Looking for some Networking Assistance?
Contact me directly at jcarvaja@laguiadelnetworking.com
I will fix your problem ASAP.
Cheers,
Julio Carvajal Segura
http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hi Julio , thnkx a lot , but again
IPSec over gre. , can it de done as remote access vpn ?
Or it must be site-site vpn ?
I googled a lot and haven't yet find any one talk about remote access IPSec over gre .
It always says gre /IPSec between two points at least
