Flexible netflow in port-channel
Hello
I need to configure flexible netflow in L3 port-channel interface at WS-C3850-12XS  IOS Version 16.3.3, but it,s not possible.
MG_CORE(config-if)#ip flow monitor Netflow-Monitor-In input
% Flow Monitor: Failed to add monitor to interface: flexible netflow not supported on port channels
In the following documentation, says that it is supported.
Flexible NetFlow is not supported on the L3 port-channel member ports, but is supported on the L3 port-channel interface.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-3/configuration_guide/b_163_consolidated_3850_cg/b_162_consolidated_3850_cg_chapter_01000111.html
Please, help.
thanks
12 Replies 12
Rob Cluett
Which are you trying to add it to?  The port-channel or the members?
I trie to add in port-channel
MG_CORE(config)#interface port-channel 1
As Reza pointed out, add it to the members rather than the port-channel.
I have configured Netflow in the port TE1/0/10 and TE2/0/10, but Netflow are not working.
This is the configuration.
flow record Netflow-In
match flow direction
match interface input
match ipv4 destination address
match ipv4 protocol
match ipv4 source address
match ipv4 tos
match transport destination-port
match transport source-port
collect interface output
collect counter bytes long
collect counter packets long
flow exporter Netflow_SRV
destination 10.1.10.141
source Port-channel1
transport udp 9996
cache timeout inactive 10
cache timeout active 60
record Netflow-In
MG_CORE#sh interfaces port-channel 1 etherchannel
Age of the Port-channel = 15d:02h:58m:05s
Logical slot/port = 12/1 Number of ports = 2
GC = 0x00000000 HotStandBy port = null
Passive port list = Te1/0/10 Te2/0/10
Port state = Port-channel L3-Ag Ag-Inuse
Protocol = -
Port security = Disabled
Ports in the Port-channel:
Index Load Port EC state No of bits
0 00 Te1/0/10 On 0
0 00 Te2/0/10 On 0
Time since last port bundled: 12d:23h:04m:54s Te2/0/10
Time since last port Un-bundled: 12d:23h:06m:20s Te1/0/10
interface TenGigabitEthernet1/0/10
description *** ENL a ROUTER 7600 puerto G5/1 ***
no switchport
no ip address
channel-group 1 mode on
end
interface TenGigabitEthernet2/0/10
description *** ENL a ROUTER 7600 puerto G6/1 ***
no switchport
no ip address
end
MG_CORE#sh flow monitor Netflow-Monitor-In statistics
Cache type: Normal (Platform cache)
Cache size: Unknown
Current entries: 0
Flows added: 0
Flows aged: 0
Can you change the source to physical interface and test again?
no source Port-channel1
source tenGigabitEthernet1/0/10
It's common practice to use the Loopback IP (i.e. loopback0) of the router as the source address.  Reza's test will work with the tenGigabitEthernet source though.
Reza Sharifi , 2rcluett
I have change the source interface to Ten1/0/10, but the problem persist
Cache size: Unknown
Current entries: 0
Flows added: 0
Flows aged: 0
Can you see any netflow traffic destined for the Netflow server leaving the router?  You should be able to run a packet capture from the box if running the appropriate code.
Also may be worthwhile to reduce your netflow statements down to the bare minimum.  It may help isolate the issue. Try it with the simplest Netflow config you can muster up.
I don't think this will work for a comparison because I'm running Netflow v9. This is the extent of my Netflow config on IOS routers.
ip flow-capture vlan-id
ip flow-export source Loopback0
ip flow-export version 9
ip flow-export destination 10.24.1.17 19206
ip flow-top-talkers
 top 10
 sort-by bytes
I have the same issue. I applied it on the physical interface with no avail.
Reza Sharifi
It is not supported under the Portchannel interface. It is only supported on the physical interfaces belonging to Portchannel 1 (in your case).
I have an issue and I am looking for some help
I have a number of port channels on a fibre link.
one pair of the fiber 5&6 are faulty. After they have been tested by our fibre guys I wish to take this
pair out fo the port channel and test thew with a vlan. I also want to send traffic down this link over 2 hours and send it to Wireshark
Any ideas?
Michael
