multicast with MSDP, BGP and PIM
Jacek Tymoczko
I'm new into multicast and I got a setup to do, we have already a multicast running on our Catalyst 6500 VSS. But recently we need to peer with a customer and get a multicast from him using MSDP, BGP and PIM.
First, I would like to somehow "isolate" current multicast from the one I will be receiving from the new customer on this peer connection. So normally now the multicast clients are in Vlan110 and I want them be there. But for new customer multicast I would like to have new VLAN for clients. So I was wondering how to achieve multiple Randezvous Point (RP) ? I read about static RP with filter, but one filter per RP is possible, and on the RP 172.16.10.1 I got few multicast groups addresses, so that is kind of tricky.
I was also wondering to create a new VRF for that connection and put the port which will be peering with the customer in that VRF. Would it make easier ?
Below I put the parts of config which refer to multicast and OSPF we run now for our internal multicast.
Any help would be welcomed.
The config is as follows:
ip multicast-routing
ip multicast-routing vrf backend
interface Vlan110
 ip vrf forwarding backend
 ip address 172.16.10.1 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip pim sparse-mode
interface Vlan300
 ip address 192.168.1.1 255.255.255.128
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip pim dr-priority 255
 ip pim sparse-mode
interface Vlan301
 ip address 192.168.1.129 255.255.255.128
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip pim sparse-mode
router ospf 1 vrf backend
 router-id 172.16.3.255
 log-adjacency-changes
 passive-interface default
 no passive-interface Vlan110
 no passive-interface Vlan300
 no passive-interface Vlan301
 network 172.16.10.1 0.0.0.0 area 0
 network 192.168.1.1 0.0.0.0 area 0
 network 192.168.1.129 0.0.0.0 area 0
ip pim bidir-enable
ip pim rp-address 172.16.10.1
ip pim vrf backend rp-address 192.168.1.1
ip pim vrf backend autorp listener
0 Replies 0
