Flexible Netflow on Cisco Catalyst 9600 switch
carl_townshend
Hi Guys
We have netflow configured on our 9600 switch, however it does not appear to be working, it could be our monitoring server but I just wanted to double check we have the correct config
We have a L3 vlan and netflow is applied currently as the below for this vlan
vlan configuration 126
ip flow monitor NETFLOW-IN input
ip flow monitor NETFLOW-OUT output
Is this the correct way to apply it to the interface, or should it be applied under the L3 SVI interface?
Cheers
5 Replies 5
M02@rt37
Hello @carl_townshend,
If you only want to monitor traffic that is within the same VLAN, then the configuration you provided should be sufficient. If you want to monitor traffic that is being routed between different VLANs, you should apply the NetFlow configuration on the Layer 3 SVI for each VLAN that you want to monitor.
Best regards
Hi there
So when you say within the vlan? surely the flows will include source and destination IPs coming in and out of the vlan ?
or will it only show you flows on that subnet and only that subnet between each other?
cheers
 This command should be applied under the interface vlan (SVI)
But, this is not enough. The steps to setup netflow is as follow:
  • Create a flow record by specifying keys and non-key fields to the flow.
  • Create an optional flow exporter by specifying the protocol and transport destination port, destination, and other parameters.
  • Create a flow monitor based on the flow record and flow exporter.
  • Create an optional sampler.
  • Apply the flow monitor to a Layer 2 port, Layer 3 port, or VLAN.
You can take a look on this guide.
https://www.noction.com/blog/cisco-catalyst-netflow-configuration
https://www.cisco.com/en/US/docs/switches/lan/catalyst3850/software/release/3se/consolidated_guide/b_consolidated_3850_3se_cg_chapter_011010.html#task_1C8520F2E2F243E6B7B9F2C4C144B27C
I forgot to add, we have all the other things set, flow record, exporter etc.
it’s more where to apply it, as per the other poster, do I need to apply it under the layer 3 interface rather than under the vlan configuration prompt?
cheers
 That´s correct.
