Nat translation from LAN
Apeiron
Hello, I'm a student working on a final year project and I would appreciate any help !
I want to Ping a server on the outside, it has the ip of 10.0.0.10 /24
I'm using a PC in VLAN 50 with the address of 192.168.50.11 /24
Using the simulation mode in packet tracer i see the ping is getting to the server translations are happening okay. But it fails at the CE 2811 router
Here is the configuration
Thanks in advance!
 Take a look on this file. It is working.
 What I changed.
On router SE, you put a default route down to CE. This is necessary. the traffic coming from CE will be Natted to  220.110.0.2:
 "ip nat inside source list NAT interface Serial0/3/0 overload"
As the packet reaches SE with IP address of 220.110.0.2, it know how to reply.
On the Core, you need to have default route to CE.
S* 0.0.0.0/0 [1/0] via 192.168.1.1
And then, you need to add two more commands on the OSPF:
router ospf 1
log-adjacency-changes
redistribute static
network 0.0.0.0 255.255.255.255 area 0
default-information originate
With this two command you are going to send all the distribuition a default route so that any route they dont know they send to the Core.
Last but not least, you need to remove this config on the SE router:
interface FastEthernet0/0
ip address 10.0.0.1 255.0.0.0
ip nat inside
duplex auto
speed auto
You dont need to do NAT on the LAN interface on this case.
8 Replies 8
can you share the PKT file (zip it before upload) because i cant see where is your PC located
Good luck
KB
thanks for the response!
Apeiron
thanks all!
 You need a route on the CE route like this:
 ip route 192.168.50.0 0.0.0.255  <router 2811 Interface>
On the router 2811 you need to have route pointing the Server network.
Where did you apply the NAT ?
Thanks i will try this now and
I've applied the NAT overload on the CE router and a static NAT on SE router
 Double NAT is complicate. You need to mind the routing very carfully. Keep in mind the the route must be placed basec on the Natted IP address and not on the original IP address.
   You can share the PKT file here and it would be easier to help. You just need to zip it first.
 What I changed.
router ospf 1
redistribute static
ip nat inside
duplex auto
speed auto
Thanks for the help!!
