FlexLink+ Preemptive configuration
Dears,
I have the following configuration done for backup interfaces (FlexLink+), my question is that does this feature support automatic preemption for the primary and secondary interfaces?
As when i enable the primary port by no-shut the link from the other end, it does not restore the "Open" state, and the secondary stays the "Open" port.
interface GigabitEthernet1/1/1
switchport trunk allowed vlan 310,350
switchport mode trunk
rep segment 1 edge no-neighbor primary
end
interface GigabitEthernet1/1/2
rep segment 1 edge no-neighbor preferred
end
Actually, i have implemented the following command instead and it it worked:
event manager applet Interface-UP
event syslog pattern "%LINK-3-UPDOWN: Interface GigabitEthernet1/1/1, changed state to up"
action 5.0 cli command "enable"
action 5.1 cli command "conf t"
action 5.2 cli command "interface g1/1/2"
action 5.3 cli command "shut"
action 5.4 cli command "end"
event manager applet interface-Down
event syslog pattern "%LINK-3-UPDOWN: Interface GigabitEthernet1/1/1, changed state to down"
action 5.5 cli command "enable"
action 5.6 cli command "conf t"
action 5.7 cli command "interface g1/1/2"
action 5.8 cli command "no shut"
action 5.9 cli command "end"
6 Replies 6
balaji.bandi
what switch model is this and IOS Code running : check example delay :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/17-2/configuration_guide/lyr2/b_172_lyr2_9500_cg/configuring_flexlink_plus.html#id_137012
BB
switch model is 9200 IOS version 16.x.
I followed the document with no luck.
did not have hands-on Cat 9200,
but interesting check below link some facts :
https://community.cisco.com/t5/switching/flexlink-support-on-catalyst-9000-series/td-p/3496864
BB
The only thing they say, is that the feature is deprectaed!!!
How is that possible, as still we are able to configure it using the "rep" commands, and as shown in the document shared by you earlier???
Sure EEM is other options was about to suggest, but glad you able to resolve the issue.
BB
