FlexWan module and SUP720
nawas
Level 4
Level 4
Is the flexwan module part number WS-X6182-2PA supported in WS-SUP720 BASE? or do I need to buy an enahanced FlexWan,?
rwyates_2
It is supported. You just need to make sure you have the right code on the 720.
ajagadee
Nawas,
WS-X6182-2PA is supported on SUP720 and refer below some of the information that will come handy when you order the parts.
On SUP720, you need WAN Feature set Software to support the WS-X6182-2PA module. When you go to the download page, you can see the image filename that as "_wan" and these images should support WS-X6182-2PA.
And also, WS-X6182-2PA is End of Sale and already past Last Shipment Date of April 15, 2006. Please refer the below document for replacement parts:
http://www.cisco.com/en/US/products/hw/routers/ps368/prod_eol_notice0900aecd802e9c57.html
FLEXWAN :
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a00800923bf.html#wp1002300
Let me know if it helps.
Arul
** Please rate all helpful posts **
