Flowcontrol - Throughput issues
Brendan Marmont
Level 4
Level 4
This is one example, I have a NAS 10GbE connected to a 4507 10GbE interface. When I copy a large CIFS file, the resource reports are telling us we are getting 20-30MBs, OS tells us 7MBs? Apart from the obvious reported throughput differences, thats slow!
Devices IPs are in the same subnet, Interface config
interface TenGigabitEthernet5/10
description QNAP 10GbE
switchport access vlan 10
switchport mode access
spanning-tree portfast
I'm not so familiar with flowcontrol (Just yet ) could this be affecting our system throughput negatively? The show flowcontrol output is not consistant, I have listed the 10GbE line cards stats below.
Some explanation as to why some Flowcontrol operations are 'on' 'off' 'disagree' and why Recieve Admin is set to 'desired' and 'on' - is this automatically generated by the system, I certainly did not specify these configurations.
Port       Send FlowControl  Receive FlowControl  RxPause TxPause
           admin    oper     admin    oper
Te5/1      on       on       desired  on          325168  3773725
Te5/2      on       on       desired  on          166494  3847509
Te5/3      on       on       on       on          43476   65887
Te5/4      on       on       on       on          489200  1649744
Te5/5      on       on       desired  on          595828  1607934
Te5/6      on       on       on       on          11910638 6504
Te5/7      on       off      on       off         1974    26
Te5/8      on       off      desired  off         14      0
Te5/9      on       off      on       off         4470    4
Te5/10     on       on       on       on          25704   0
Te5/11     on       off      desired  off         0       0
Te5/12     on       on       desired  on          11915312 0
Thanks in advance
Brendan
Reza Sharifi
It is common to have jumbo frames enabled on the device where storage connect to.  Is jumbo frame enabled?
I've tried a MTU 9000 and the throughput still performs like a 10MB link.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Are both your resource reports and OS measuring in bits per second or bytes per second?  Networks often report in the former and OSs in the later.  Also, sometimes network stuff also accounts for bandwidth being used by L2, often OSs do not.
With CIFS, older versions of SMB weren't too optimal for high speed links. Additionally, if running over TCP, older Windows devices (pre-NextGen) didn't allocate very large TCP RWINs.  However, from your very low rate, which is lower than I would expect even with older SMB and/or pre-NextGen TCP, your NAS is 10g, but what about the host?  I'm wondering whether you NAS sends bursts that are being dropped if bandwidth to the host is less than 10g.  If your NAS keeps cycling through slow start - that might account for your slow overall transmission rate.
Of course, there are many other possible issues to.  For example, your (?) 4712 line card is, by design, oversubscribed 2.5:1.
BTW, "ordinary" Ethernet flow-control often "hurts" performance.
