Forget System of router
omar Alqadi
Hi;
i have router 2911 and i can't access by  Username and password for  first time open
when i tried to recovery of password ,i removed compact flash and i run the system ,
Once the router is on Rommon mode, i reinsert the compact flash,
i Type confreg 0x1b340 instead of  Type confreg 0x2142  and i Type reset
after  reboot  the ios forget as per attached picture  .
i try same Steps but the problem still.
please we need solution to return System
Eric23
Change the speed rate of the console cable 1200
Here is the link which guide you for the password recovery process.
Below is the default settings for serial line
• Bits per sec: 9600
• Data bits: 8
• Parity: none
• Stop bits: 1
• Flow control: none
You can try changing these values or Bits per sec for the issue you are facing.
Spooster IT Services Team
