Frame Relay - basic question
joeadiutori
Level 3
Level 3
Hi All,
I have 2 routers back-to-back in my lab.  I'm trying to configure Frame Relay.  For now I'm just trying to ping from 12.1 to 12.2 but it's not working.  The serial interfaces on both routers are up and up.  And prior to implementting Frame Relay my pings were successful.
Any ideas???
ROUTER 1:
interface Serial1
ip address 192.168.12.1 255.255.255.0
ip nat inside
encapsulation frame-relay
no keepalive
frame-relay map ip  192.168.12.2  63
ROUTER 2:
interface Serial0
ip address 192.168.12.2  255.255.255.0
no ip directed-broadcast
no keepalive
clockrate 56000
frame-relay map ip  192.168.12.1  65
acampbell
One of your routers needs to be a frame relay DCE the other DTE (default)
As router 2 is the DCE end of the back to back we will make it the DCE for frame relay too.
ROUTER 2:
interface Serial0
frame-relay intf-type dce
As this is point to point with no frame relay switch cloud in the middle we need to use the same DLCI at both ends
ROUTER 1:
interface Serial1
ip nat inside
no keepalive
frame-relay map ip 192.168.12.2 101 broadcast
bandwidth 56
ROUTER 2:
interface Serial0
no keepalive
clockrate 56000
frame-relay map ip 192.168.12.1 101 broadcast
bandwidth 56
Hopefully now it will work
show frame pvc
show frame lmi
you should see that the DLCI is active in both routers
yoiu should see LMI stats incrementing
Ping accroos the network
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
5 Replies 5
acampbell
ROUTER 2:
interface Serial0
ROUTER 1:
interface Serial1
ip nat inside
no keepalive
bandwidth 56
ROUTER 2:
interface Serial0
no keepalive
clockrate 56000
bandwidth 56
show frame pvc
show frame lmi
Alex
It's working now.  12.1 can ping 12.2.  The only thing I changed was the DLCI.
ROUTER 1:
interface Serial1
ip nat inside
no keepalive
ROUTER 2:
interface Serial0
no keepalive
clockrate 56000
Reza Sharifi
You need to clock the site that is DCE.  If you do a "sh contr inter s0" and s1, it will tell you which side is DCE.
in your case you clock r2.  Is this the DCE site?
joeadiutori
Level 3
Level 3
ACCMPBELL - I will now implement the suggestions and let you know
REZA - I think clocking is OK.  At least prior to configuring Frame Relay everything was working fine.  I also configured PPP and that worked fine.  HDLC works fine.  This tells me the clocking is working.  Do you agree?
Any ideas???
ROUTER 1:
interface Serial1
ip nat inside
no keepalive
ROUTER 2:
interface Serial0
no keepalive
clockrate 56000
What is the ip nat inside doing? Maybe remove it and try
Kishore
