Frame relay command not working on ethernet interface
hfakoor222
its a default config router loaded in GNS 3, the frame-relay is working on serial interface 2022-03-01 07_42_29-Free CCNA _ Dynamic Routing _ Day 24 _ CCNA 200-301 Complete Course - YouTube.png
but it is not working on a ethernet interfaqce on same router
Any suggestions?
You are correct. encapsulation frame-relay is supported on serial interfaces and not supported on Ethernet interfaces. This is generally true and is not related to being in GNS 3.
Rick
hfakoor222
It is looking like it may not be supported
Rick
I am glad that my explanation was helpful. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
