WS-C3750X-24P-S : Switch FAN Led status shows amber .
Hello Experts ,
We have issue with switch FA , on cli it show faulty and when physically checked the LED status it shows Amber color .
So in this scenario do you think we can consider FAN as faulty or can we try reseating the FAN again to see if that works
what is the correct approach ?
Switch Model : WS-C3750X-24P-S
Do we have any command to check serial number of the fan ? I did not find in show inventory !
balaji.bandi
show env {all | fan | power [all | switch [switch-number]] | rps | stack [switch-number] | temperature [status]} [ | {begin | exclude | include} expression]
show env all    - show you fan status
If you like to reseat them,  i suggest to do in the maintenance window.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/hardware/install/notes/fan_note.html
BB
Leo Laohoo
IF the LED on the fan assembly is amber then it is not a bug but a failure.
Like the power supplies, the fan assembly for the 3750X is the same model as the ones found in 3850 and 9300.
