Frame-Relay with two Routers(frame-relay switches) in frame-relay cloud
daudparvez
I am using following lab in GNS3 with two routes (frame-relay switches) in Frame-Relay cloud.
The interaces of these two routers connected to each other have been configured with nni type. However, my PVCs are not coming up.
configurations of the R1 and R6 are as follows:
_______________________ R1_______________________
interface Serial0/0
no ip address
encapsulation frame-relay
serial restart_delay 0
clockrate 1008000
frame-relay lmi-type cisco
frame-relay intf-type dce
frame-relay route 103 interface Serial0/1 553
interface Serial0/1
no ip address
shutdown
clockrate 1008000
no frame-relay inverse-arp
frame-relay intf-type nni
frame-relay route 551 interface Serial0/0 103
__________________________R6_______________________
interface Serial0/0
no ip address
clockrate 1008000
frame-relay route 301 interface Serial0/1 551
interface Serial0/1
no ip address
clockrate 1008000
frame-relay route 553 interface Serial0/0 301
May be I am missing some command.Please help in resolving the issue.
Best Regards,
Hello Daud,
After so many suggestions about corrections, I have lost track of what is your final state of configuration.
Please try to paste the following lines into your routers R1 and R6. They will reset the configuration of your S0/0 and S0/1 interfaces to default and configure them from scratch. If it does not help then please post the complete config of S0/0 and S0/1 interfaces from both R1 and R6. I have tested this configuration and it worked for me.
default interface Serial0/0
interface Serial0/0
no shutdown
no ip address
default interface Serial0/1
interface Serial0/1
no shutdown
no ip address
frame-relay route 553 interface Serial0/0 103
interface Serial0/0
no shutdown
no ip address
frame-relay route 301 interface Serial0/1 553
interface Serial0/1
no shutdown
no ip address
Best regards,
Peter
P.S.: How did the thread with the OSPF over NBMA networks continue? I somehow lost track of it lately.
10 Replies 10
cadet alain
Can you try this:
R1
int s0/1
R2
int s0/1
frame-relay route 551 interface Serial0/0 301
Regards.
Alain
Still no working
post output of followinf on the DTE devices:
-sh frame map
-sh frame pvc | i STATUS
-sh frame lmi
Regards.
Alain
ebarticel
Level 4
Level 4
May I ask if you enabled frame relay switching in global mode?
Hope this helps
Eugen
On a back to back frame relay, you have to turn LMI off by issuing a "no keepalive" on the interfaces. You may also have to convert these to point-to-point
links by moving your dlcis and addressing to a subinterface.
But, I also see your s0/1 is shut on R1....
HTH, John *** Please rate all useful posts ***
daudparvez
Tried the "no keepalive" command too but with no result.
Here are the outputs of few show commands for R1 and R6:
__________R1____________________
R1#sh frame-relay pvc
PVC Statistics for interface Serial0/0 (Frame Relay DCE)
              Active     Inactive      Deleted       Static
  Local          0            0            0            0
  Switched       0            1            0            0
  Unused         0            0            0            0
DLCI = 103, DLCI USAGE = SWITCHED, PVC STATUS = INACTIVE, INTERFACE = Serial0/0
  input pkts 0             output pkts 0            in bytes 0
  out bytes 0              dropped pkts 0           in pkts dropped 0
  out pkts dropped 0                out bytes dropped 0
  in FECN pkts 0           in BECN pkts 0           out FECN pkts 0
  out BECN pkts 0          in DE pkts 0             out DE pkts 0
  out bcast pkts 0         out bcast bytes 0
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
  switched pkts 0
  Detailed packet drop counters:
  no out intf 0            out intf down 0          no out PVC 0
  in PVC down 0            out PVC down 0           pkt too big 0
  shaping Q full 0         pkt above DE 0           policing drop 0
  pvc create time 00:06:12, last time pvc status changed 00:06:02
PVC Statistics for interface Serial0/1 (Frame Relay NNI)
  Local          0            0            0            0
  Switched       1            0            0            0
  Unused         1            0            0            0
DLCI = 551, DLCI USAGE = SWITCHED, PVC STATUS = INACTIVE, INTERFACE = Serial0/1
LOCAL PVC STATUS = ACTIVE, NNI PVC STATUS = INACTIVE
  switched pkts 0
  pvc create time 00:06:13, last time pvc status changed 00:04:59
DLCI = 553, DLCI USAGE = UNUSED, PVC STATUS = ACTIVE, INTERFACE = Serial0/1
LOCAL PVC STATUS = ACTIVE, NNI PVC STATUS = ACTIVE
  switched pkts 0
  pvc create time 00:04:59, last time pvc status changed 00:04:59
R1#
R1#sh frame-relay map
********NOTHING IN THE OUTPUT*******
R1#sh ip int b
Interface                  IP-Address      OK? Method Status                Protocol
Serial0/0                  unassigned      YES NVRAM  up                    up
Serial0/1                  unassigned      YES NVRAM  up                    up
Serial0/2                  unassigned      YES NVRAM  up                    down
Serial0/3                  unassigned      YES NVRAM  up                    down
Ethernet1/0                unassigned      YES NVRAM  administratively down down
Ethernet1/1                unassigned      YES NVRAM  administratively down down
Ethernet1/2                unassigned      YES NVRAM  administratively down down
Ethernet1/3                unassigned      YES NVRAM  administratively down down
R1#
R6(config-if)#do sh frame-relay pvc
  Local          0            0            0            0
  Switched       0            1            0            0
  Unused         0            0            0            0
DLCI = 301, DLCI USAGE = SWITCHED, PVC STATUS = INACTIVE, INTERFACE = Serial0/0
  switched pkts 0
  pvc create time 00:04:25, last time pvc status changed 00:04:24
  Local          0            0            0            0
  Switched       1            0            0            0
  Unused         1            0            0            0
DLCI = 551, DLCI USAGE = UNUSED, PVC STATUS = ACTIVE, INTERFACE = Serial0/1
  switched pkts 0
  pvc create time 00:03:17, last time pvc status changed 00:02:17
DLCI = 553, DLCI USAGE = SWITCHED, PVC STATUS = INACTIVE, INTERFACE = Serial0/1
  switched pkts 0
  pvc create time 00:04:28, last time pvc status changed 00:04:18
R6(config-if)#do sh frame-relay map
R6#sh ip int b
Serial0/2                  unassigned      YES NVRAM  administratively down down
Serial0/3                  unassigned      YES NVRAM  administratively down down
R6#
If someone has experience to deal with such scenario, please help.
Best Regards,
Check this configs:
R1
R6
The mappings don't match. Should be the same 2 DLCI on each router just inverse them. R1 has 103 and 553 adn R6 has 301 and 551
Hope this helps
Eugen
daudparvez
Dear Eugen,
Tried but with no result.
Can someone please guide :::(
Hello Daud,
interface Serial0/0
no shutdown
no ip address
interface Serial0/1
no shutdown
no ip address
interface Serial0/0
no shutdown
no ip address
interface Serial0/1
no shutdown
no ip address
Best regards,
Peter
Dearest Peter and other friends,
Thankyou very much for your sincere help. At last my PVCs got up with the configuration suggested by Peter. Frame - Relay is really screwing my mind now a days, but many things got cleared to me with your kind guidence and help.
The thread with OSPF over NBMA has been left un pursued by me due to my engagement in the current thread. Now that this problem is solved, I will continue to this from tomorrow. Will request your help in case I got stuck at some point.
Once again, Thanks all for your support.
