frame relay
carl_townshend
Hi all, can anyone tell me what speeds you can get frame relay on in the uk ?
Tim Smith
Level 4
Level 4
Hi Carl,
Normal frame relay usually goes up to around the 2Mbps mark for the access. The standard Cisco serial WIC's top out at 2Mbps as well.
You can have a guaranteed rate (CIR) of anything under that. Probably usually in 16kbps increments.
Depending on how many sites you have - a lot of company's are going for IP WAN style solutions. This way you can have 1 network with different access pipes to each office. Frame relay, DSL, Ethernet. Much more flexible approach.
Cheers,
Tim.
kevindickerson
Hi Carl,
What speed do you want! you can get anything from 64kbps up to 622Mbps. You can also get Gigabit Ethernet services depending upon the distances involved.
Kevin
well, what media can you run frame relay over, does it have to be serial ?
