11-22-2006 07:31 AM - edited 03-05-2019 12:58 PM
I have encountered these two Log messages and the Giga port on the Switch blocked as
if it had port security. The port is directly connected to the Core Lan Switch.
Nov 22 08:41:13: %SPANTREE-2-LOOPGUARD_BLOCK: Loop guard blocking port GigabitEt
hernet0/2 on VLAN0001.
Nov 22 08:41:13: %SPANTREE-2-LOOPGUARD_UNBLOCK: Loop guard unblocking port Gigab
itEthernet0/2 on VLAN0001.
What may be the reason? What should i check?
Solved! Go to Solution.
11-22-2006 07:40 AM
Hi Eloy,
The above log messages on the switches indicates that the spanning tree message age timer has expired, because no BPDUs were received from the designated bridge. Because this condition could be caused by an unidirectional link failure, the interface is put into blocking state and marked as loop guard inconsistent in order to prevent possible loops from being created.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_1_19/message/emsg.htm#1186228
Use the show spanning-tree inconsistentports command to review the list of interfaces with loop guard inconsistencies. Determine why devices that are connected to the listed ports are not sending BPDUs. One reason could be that they do not run the Spanning Tree Protocol; in this case, you should disable loop guard in the inconsistent interfaces or start the spanning tree protocol on the other side of the links, depending on the context. Another reason could be a failure in the cable: If the link has a failure that makes it unidirectional (you can transmit but you cannot receive), you should replace the old cable with a new cable.
HTH, Please rate if it does.
-amit singh
11-22-2006 07:40 AM
Hi Eloy,
-amit singh
11-22-2006 09:12 AM
FYI.
Show interface of Floor Switch
interface GigabitEthernet0/1
description Hacia Core
switchport mode trunk
flowcontrol receive desired
udld port
end
Show interface of CORE Lan Switch
interface GigabitEthernet4/2
description Trunk Piso3.1
logging event link-status
udld port
flowcontrol send desired
rmon native
rmon collection stats 11 owner config
Any other advice?
