07-18-2019 04:23 AM
Hi Experts,
Our customer complaints of frequent reboot of a few Cisco switches
Pls find the logs:
*Mar 1 00:00:05.830: Read env variable - LICENSE_BOOT_LEVEL =
Mar 30 01:27:41.489: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = ie2k Next reboot level = lanlite and License = No valid license found
Mar 30 01:27:41.841: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = ie2k Next reboot level = enhancedlanbase and License = enhancedlanbase
------------------ show version ------------------
Cisco IOS Software, S5700 Software (S5700-UNIVERSAL-M), Version 15.2(3)EA1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Tue 17-Feb-15 13:42 by prod_rel_team
ROM: Bootstrap program is IE2000 boot loader
BOOTLDR: IE2000 Boot Loader (IE2000-HBOOT-M) Version 15.2(3r)E, RELEASE SOFTWARE (fc1)
CE5_Switch uptime is 2 weeks, 2 days, 5 hours, 13 minutes
System restarted at 01:27:33 UTC Wed Mar 30 2011
Reason for reboot is showing unknown.
License Level: enhancedlanbase
License Type: Permanent
Next reload license Level: enhancedlanbase
cisco 1783-BMS10CGN (PowerPC405) processor (revision M0) with 262144K bytes of memory.
Solved! Go to Solution.
07-18-2019 05:17 AM
07-18-2019 05:17 AM
07-18-2019 07:42 AM
Thank you Mark for the quick response.
Just wanted to know one more thing, does the logs in the switch suggest something, particularly "%IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = ie2k Next reboot level = lanlite and License = No valid license found "
Thanks in advance
07-18-2019 07:56 AM
07-18-2019 08:12 AM
Unfortunately I wont be able to do that, since our vendor has gone to this site and sending him back can be next to impossible. Still I can check if that is possible.
Meanwhile Mark you mean to say lanlite license may be still active above enhancedlanbase which is why I may be getting that alert ?
It may be silly to ask but clearing up things, if I have enhancedlanbase wont it override lanlite ?
07-18-2019 08:22 AM
07-18-2019 08:33 AM
Thank you Mark. My questions are answered, still if I can get a show license I would surely post it.
Cheers!
07-18-2019 10:35 AM
Mark, I had another switch which had the following config:
JKT_L2_UPACK#show version
Cisco IOS Software, S5700 Software (S5700-UNIVERSAL-M), Version 15.2(4)EA, RELEASE SOFTWARE (fc2)
Compiled Mon 28-Sep-15 23:41 by prod_rel_team
JKT_L2_UPACK uptime is 25 weeks, 3 days, 3 hours, 54 minutes
Last reload reason: power-on
and in another one where Last reload reason says : Unknown.
In my original case there was no last reload reason..why so ?
07-19-2019 12:23 AM
07-19-2019 12:27 AM
Alright, would do, thank you Mark.
