09-19-2011 06:37 AM - edited 03-07-2019 02:18 AM
Hi, got a faulty router 2821 with etherswitch module (NME-16ES-1G-P) which I transferred into my 2811 router. The module has no error however the switch module doesn't give any power to our 3 APs (which are getting its power to this module). But it was working (the POE) when the module was inside the faulty 2821 router.
Hope anyone can help me.
09-19-2011 07:07 AM
Dear Red,
Please check in "sh ver" ,whether switch module is being sensed by the IOS.
Please share the exact IOS on the router.
Ameya
09-19-2011 06:31 PM
Hi Ameya,
Here's the sho ver on the 2811 (below) but I also used the ios from the old router 2821 (c2800nm-ipvoice-mz.124-1c) which used to be working however when I transferred it to the 2811 it doesn't work.
tia
Router2811#sho ver
Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 12.4(25f), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 16-Aug-11 07:26 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Router2811 uptime is 1 hour, 10 minutes
System returned to ROM by reload at 06:02:37 UTC Mon Sep 19 2011
System restarted at 06:03:44 UTC Mon Sep 19 2011
System image file is "flash:/c2800nm-ipvoicek9-mz.124-25f.bin"
Cisco 2811 (revision 53.51) with 245760K/16384K bytes of memory.
Processor board ID FHK1124F0AK
2 FastEthernet interfaces
1 Gigabit Ethernet interface
1 Serial(sync/async) interface
1 terminal line
6 Voice E & M interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
09-20-2011 12:04 AM
Hi Redrobish,
As i suspected, ur current IOS is incompatible,
Sh ver is not showing the ether module.
You will have to find the right IOS for your router to sense the ethernet module.
Will try to share the exaco IOS soon.
Please rate if helps.
Ameya
09-20-2011 12:13 AM
Hmm interesting! On my old 2821, the sho ver didn't show the etherswitch module as well but its working and I also used the old router's IOS (c2800nm-ipvoice-mz.124-1c) to the new router 2811 to make sure but still doesn't work....pls. let me know what particular IOS so I can try.
many thanks
09-20-2011 06:48 AM
12.4 shoud support that module - 12.4(1) is the minimum needed for this module on the 2800 routers. it could however be a power supply issue, have a look at table 9 in this link -
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8028d15f.html
Jon
09-20-2011 09:14 AM
Hi jon,
On the table 9 (of the link), both the 2821 and 2811 requires upgrading the router's internal power supply to an AC-IP version? How come our old faulty 2821 doesn't need to have an AC-IP power? Can you pls. clear this and how to check if it exist?
thanks jon
