From Outside how to access to inside and redirect all 443 port in DA server?
Lost & Found
Level 2
Level 2
I would like to ask how can I route from outside to inside.
I'm planning to set-up a Direct access server so the user can access the drive in their home.
any Idea about this setup??
please see the attached photo.
thanks
Shawn Guertin
What is the firewall?
In a cisco router that would be in the NAT:
ip nat inside source static tcp [inside_server_IP] [inside_port] interface [interface_name] [outside_port_to_redirect]
Else, precise the firewall/NAT device.
How about using a firewall? I'm using cisco ASA 5510.
Have you tried to setup DA using microsoft 2012?
thanks
