FRU-power failed on catalyst 76xxx
ROBERTO TACCON
Level 4
Level 4
Hi to All,
please can you tell me what is the "FRU-power failed" ? It's a hardware problem on the module on the catalyst backplane or on the power-supply ?
Aug 28 08:48:03.079 MET-DST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1, changed state to down
Aug 28 08:48:03.111 MET-DST: %OIR-6-REMCARD: Card removed from slot 1, interfaces disabled
Aug 28 08:48:03.423 MET-DST: %MLSM-6-MMLS_MODE_CHANGE: MMLS: Replication Mode Change Detected because oir event
Aug 28 08:48:03.106 MET-DST: %C6KPWR-SP-4-DISABLED: power to module in slot 1 set off (Reset)
Aug 28 08:48:04.631 MET-DST: %BGP-5-ADJCHANGE: neighbor 82.98.12.xxx Down Interface flap
Aug 28 08:48:16.227 MET-DST: %OIR-SP-6-PWRFAILURE: Module 1 is being disabled due to power convertor failure
Aug 28 08:48:16.227 MET-DST: %C6KPWR-SP-4-DISABLED: power to module in slot 1 set off (FRU-power failed)
cisco#sh power
Load for five secs: 11%/0%; one minute: 7%; five minutes: 8%
Time source is NTP, 13:27:55.112 MET-DST Wed Sep 1 2010
system power redundancy mode = combined
system power total =     3885.00 Watts (92.50 Amps @ 42V)
system power used =      1774.50 Watts (42.25 Amps @ 42V)
system power available = 2110.50 Watts (50.25 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-2500W       2331.00 55.50  OK     OK     on
2    WS-CAC-2500W       2331.00 55.50  OK     OK     on
                        Pwr-Allocated  Oper
Fan  Type               Watts   A @42V State
1    FAN-MOD-09          241.50  5.75  OK
2    FAN-MOD-09          241.50  5.75  OK
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
1    OSM-4OC3-POS-SI+     97.44  2.32     -     -     on    off (FRU-power failed)
3    WS-X6704-10GE       402.36  9.58   402.36  9.58  on    on
5    WS-SUP720-3BXL      328.44  7.82   328.44  7.82  on    on
6                          -     -      328.44  7.82  -     -
8    WS-X6724-SFP        232.26  5.53   232.26  5.53  on    on
cisco#
cisco#sh env status
Load for five secs: 59%/3%; one minute: 10%; five minutes: 9%
Time source is NTP, 13:24:48.355 MET-DST Wed Sep 1 2010
backplane:
  operating clock count: 2
  operating VTT count: 3
fan-tray 1:
  fan-tray 1 type: FAN-MOD-09
  fan-tray 1 fan-fail: OK
fan-tray 2:
  fan-tray 2 type: FAN-MOD-09
  fan-tray 2 fan-fail: OK
VTT 1:
  VTT 1 OK: OK
  VTT 1 outlet temperature: 25C
VTT 2:
  VTT 2 OK: OK
  VTT 2 outlet temperature: 24C
VTT 3:
  VTT 3 OK: OK
  VTT 3 outlet temperature: 29C
clock 1:
  clock 1 OK: OK, clock 1 clock-inuse: in-use
clock 2:
  clock 2 OK: OK, clock 2 clock-inuse: not-in-use
power-supply 1:
  power-supply 1 fan-fail: OK
  power-supply 1 power-input: AC high
  power-supply 1 power-output-fail: OK
power-supply 2:
  power-supply 2 fan-fail: OK
  power-supply 2 power-input: AC high
  power-supply 2 power-output-fail: OK
module 3:
  module 3 power-output-fail: OK
  module 3 outlet temperature: 39C
  module 3 inlet temperature: 24C
  EARL 3 outlet temperature: 31C
  EARL 3 inlet temperature: 29C
module 5:
  module 5 power-output-fail: OK
  module 5 outlet temperature: 28C
  module 5 inlet temperature: 22C
  module 5 device-1 temperature: 32C
  module 5 device-2 temperature: 33C
  module 5 asic-1 (SSO-1) temp: 21C
  module 5 asic-2 (SSO-2) temp: 22C
  module 5 asic-3 (SSO-3) temp: 22C
  module 5 asic-4 (SSO-4) temp: 22C
  module 5 asic-5 (SSA-1) temp: 22C
  module 5 asic-6 (HYPERION-1) temp: 22C
  RP 5 outlet temperature: 25C
  RP 5 inlet temperature: 25C
  EARL 5 outlet temperature: 31C
  EARL 5 inlet temperature: 21C
module 8:
  module 8 power-output-fail: OK
  module 8 outlet temperature: 33C
  module 8 inlet temperature: 24C
  module 8 device-1 temperature: 24C
  module 8 device-2 temperature: 29C
  EARL 8 outlet temperature: 28C
  EARL 8 inlet temperature: 28C
cisco#
Roberto Taccon
Giuseppe Larosa
Hello Roberto,
it is a voltage/power converter on the linecard in slot 1 that failed, and for this reason the linecard has been disabled and powered off.
It is high time for an RMA
your power supplies are working well as it can be seen in the show power.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Roberto,
Hope to help
Giuseppe
Leo Laohoo
Basically it means that the card in slot 1 is burnt.  Please contact Cisco so you are able to raise an RMA request.  Nothing can be done on your end.
