FTP UNAVAILABLE FOR ME TO UPLOAD AA PROMPTS?!
I am getting the attached error every time I simply try to upload a new recording to our UC540, something we've done many times, and nothing seems to make it stop, we have turned off everything possible to eliminate any possible conflict..
Please help?!
the usual suspects would be virus scanners on your PC, or the Windows firewall, not sure if you have tried to disable both.
Also, I have done some research, and found that there is a command to specify the source interface for (T)FTP:
ip tftp source-interface x
where 'x' should be the data vlan (likely Vlan 1).
Can you give that a try ?
