Netflow
GRANT3779
Morning All (here anyway)
I recently read that when using Netflow it should be enabled as close to the access layer as possible. I have been testing on a few access layer switches using the following template, see below(for 3650 Switches) -
The switches take the commands and I see my switch automatically appear in my Flow Collector (Stealthwatch / Flow Collector) - However I get no data from the ports.
I am assuming I cannot apply the command - ip flow monitor Monitor_SW_Flow input to actual end user access ports and it needs to be done on Layer 3 Interfaces only?
I can do this on our Core Switch SVIs no problem, but what I would be missing then is traffic between the same vlans on my Access Layer (Whether Intra or Inter Switch).
Is Netflow orientated for exporting flows crossing layer 3 boundaries rather than also catching Intra VLAN Traffic?
flow record Record_SW_Flow
match ipv4 source address
match ipv4 destination address
match ipv4 protocol
match transport source-port
match transport destination-port
match ipv4 tos
match interface input
collect interface output
collect counter bytes long
collect counter packets long
flow exporter Exporter_SW_Flow
destination 10.44.128.190
source vlan500
transport udp 2055
cache timeout active 60
cache timeout inactive 15
ip flow monitor Monitor_SW_Flow input (on all access ports)
Hi Yes because its a layer 3 command starts with ip syntax wont take on a pure layer 2 port  even though it can collect layer 2 traffic  , flex netflow needs to be applied to an ip based interface its a limitation haven't seen another way yet to collect layer 2 traffic with it
You could span the ports that would work collect it through wireshark as an option instead of netflow
8 Replies 8
Mark Malone
You need to set it to capture layer 2 traffic
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/fnetflow/configuration/xe-3s/fnf-xe-3s-book/fnf-l2-fields.pdf
Example: Configuring Flexible NetFlow for Monitoring MAC and VLAN Statistics
The following example shows how to configure Flexible NetFlow for monitoring MAC and VLAN statistics.
This example starts in global configuration mode.
flow record LAYER-2-FIELDS-1
match datalink dot1q vlan output
match datalink mac source address input
match datalink mac source address output
match datalink mac destination address input
match flow direction
exit
flow monitor FLOW-MONITOR-4
exit
ip cef
interface GigabitEthernet0/0/1
ip address 172.16.6.2 255.255.255.0
ip flow monitor FLOW-MONITOR-1 input
Hi Mark,
Thanks for the input -
I see above though you are still applying the monitor command to a L3 Interface?
I was wondering if there is a way to utilise Netflow to say capture traffic between hosts that sit on the 172.16.6.0 /24 in your example above. As traffic within this subnet would not hit the L3 Interface.
Just an update for anyone else with similar problem.
I was trying to send Netflow to Stealthwatch Flow Collector from a 6880-X but it was being dropped at the Flow Collector due to invalid template (even though I was using a template that others said worked. It may be they were sending to different collector)
The template I had to end up using to get the SW Flow Collector to accept the netflow was the following - This is for Layer 3 might I add.
 match ipv4 tos
 match ipv4 protocol
 match interface output
 collect routing next-hop address ipv4
 collect timestamp sys-uptime first
 collect timestamp sys-uptime last
Hopefully helps someone at some point.
Mark - Thanks for the input as always
Ok so I have put the following on my core switch but don't seem to be getting any flows being sent.
The below has now automatically show up on my Netflow Console (Stealthwatch) but just not giving any stats/flows. Am I missing something?
sh run | sec flow
match ipv4 protocol
destination 10.44.128.191
source Vlan500
transport udp 2055
flow monitor Flow_SW
cache entries 500000
record Record_SW
interface Vlan510
description *Server farm***
ip address 10.44.2.1 255.255.255.0
no ip redirects
no ip proxy-arp
ip flow monitor Flow_SW input
Oddly as well I can see the following -
sh flow exporter statistics
Flow Exporter Exporter_SW:
Packet send statistics (last cleared 02:16:57 ago):
Successfully sent: 10454 (11604367 bytes)
Client send statistics:
Client: Flow Monitor Flow_SW
Records added: 1726
- sent: 1726
Bytes added: 63862
- sent: 63862
But no flows appearing on my collector.
hmm flows are being sent alright looking at your output
have you tried to enable the datalink flows though , I don't use layer 2 netflow but I would think you would need these below to collect it as its the match mac rather than ip for l3
GRANT3779
Hi Mark,
Thanks, it does confirm what I was thinking from everything I read but I just wasn't quite clear.
Thanks again for your input as always.
