FWSM hostname on redundant unit
new_networker
After configuring failover on FWSM, the hostname on the secondary unit gets overwritten. Can this be avoided. I would like to identify via the hostname that which one is active.
Regards.
The code you are running A1(6.3a) doesnt support this command.
Syed Iftekhar Ahmed
Use Prompt command on primary to recongnize which one is active.
prompt hostname context state
Will add sate (primary/secondary) to the prompt.
Your prompt will show you if you are working on an Active or Standby FWSM
Syed Iftekhar Ahmed
Syed Iftekhar Ahmed
