General QoS and Switching Question
krcollab
Level 4
Level 4
All of the examples I've found for things like LLQ tend to use routed links.  I'm trying to figure out how to deal with things across an L2 trunk.  Specifically, if I have a certain type of traffic that (in cases of trunk congestion) I don't want taking up more than 50% of the trunk's bandwidth, what queuing method should I use and how is it applied (per  VLAN, per trunk interface, etc)?  I'm not looking for someone to write out a config, just a nudge in the right direction so that I know which things to go read up on.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of   the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The reason you see LLQ with routed links, is because it's normally only a feature found on routers.  Switch's "like" feature is often PQ.
Unless you need to treat VLANs (based on their VLAN ID) across a trunk differently, you often just use interface QoS using either L3 ToS or L2 CoS tags.  For example, DSCP EF or CoS 5 might be given PQ treatment regardless of the VLAN ID.
It would be traffic on a VLAN but i can do ingress marking on the few ports that will be on that VLAN.  So you're saying I should tag that traffic and then put that marking in the Priority Queue, then set a bandwidth limit on that queue while everything else will go in the default queue?   All of the queue info then gets applied to the trunk interfaces on both sides of the trunk.  Am I understanding that correctly?
