Generated .pkg in c9200
Leftz
Level 4
Level 4
Hi In switch c9200, I can see following .pkg file in flash. Usually the file .pkg is generated by .bin after command " install... " is used. but I cannot see the .bin file in flash. Where is .bin? Thanks
cat9k_lite-webui.17.03.04b.SPA.pkg
balaji.bandi
what files do you see when you issue #dir
if anyone did clean up  after installing packages (#install remove inactive)  that file may be removed from flash :
or if you installed it from TFTP with out copying in to flash: then you won't see that file.
BB
balaji.bandi
BB
Leftz
Level 4
Level 4
Thanks @balaji.bandi you are right.
